Replace & Prime Cracked Shingles? - Painting - DIY Chatroom Home Improvement Forum
Old 02-26-2013, 08:22 AM   #1
Rewards Points: 77
Replace & prime cracked Shingles?
Hello, going to start painting my house 1 section at a time over the next 1-2 years. I have some cracked shingles here and there that I'm going to replace as I've got two boxes of extra cedar shakes.
My thinking is to cut out bad shingles with a blade. Then either tack or nail? Not sure which I should use and what size? Also, Don't I have to treat new shingles before I can paint over them?
I've spent time going over the paint vs stain debate. I had a friend of mine who works for Sherwin Williams look at my house and recommend the lifetime paint over the stains. I do have a latex stain on there now that's at least several years old but dried out. However, no flaking or anything so it was done right. My friend also said to take my time and go slow and work on dry days to be sure no moisture is trapped behind the shingles before I paint. This is how to avoid paint pealing. However, some shingles are starting to curl and crack because they are so brittle.
HELP.
Thank You,
~Skelleyman
Skelleyman is offline   Reply With Quote
Old 02-26-2013, 09:05 AM   #2
Rewards Points: 13,300
Please go back and add your location to your profile.
Just go to the top right where your name is to edit.
Bad time of year to be doing any outside painting in most areas.
May be able to get those shakes out with a 12" metal cutting blade on a sawsall.
Use stainless steel ring shanked siding nains to avoid rusting and with the small heads they should not show to bad.
Old 02-26-2013, 10:03 AM   #3
Rewards Points: 77
Thanks JC. I updated that info. I'm north of Boston 20 miles, close to the seashore.
Old 02-26-2013, 10:10 AM   #4
No way would I'd be doing any outside painting in that area anytime soon. You will regret it.
Old 02-26-2013, 01:52 PM   #5
Gymschu's Avatar
Rewards Points: 492
I have great confidence in SW's Woodscapes solid color stains. Been using them for years with great, long-lasting results. Nice thing about stain is that you get no peeling. Sure, it fades a bit, but usually you get 8-10 years out of a good stain job, more if you keep up on maintenance like cleaning every couple years..
Gymschu is online now   Reply With Quote
Old 02-26-2013, 04:15 PM   #6
Rewards Points: 77
Thanks, latex or oil stain on the SW woodscapes?
Old 02-27-2013, 10:55 AM   #7
Gymschu's Avatar
Rewards Points: 492
The latex is best IMO.
Did I get ripped off? $175 to replace three shingles? Ler0y Jenkins Roofing/Siding 49 01-22-2013 03:59 PM
Shingles and tourch down COLDIRON Roofing/Siding 4 11-05-2012 10:57 PM
Replacing chimney flashing after new shingles tmiles2246 Roofing/Siding 18 04-18-2011 02:03 PM
Help! -- what is causing these shingles to fail? imaginator Roofing/Siding 1 09-18-2010 07:29 PM
Weight vs. durability of architectural shingles JoeT Roofing/Siding 10 06-29-2009 07:50 AM
