These gutters were apparently painted with an ammonia-containing latex that formed blisters which later ruptured and formed scabs (tubercules). I had to sand to bare metal and use JB Weld putty inside the gutters in some areas that were pitted completely through.
The BM technical representative recommended 2 coats of XIM Urethane Modified Acrylic (UMA) for spot priming bare metal areas. The gutters look so bad after cleaning that a full primer coat appears necessary to cover tiger striping from locked in tree sap stains and brush marks from the prior repainting. I scuffed up these areas with 100 grit paper to remove brush marks, but did not sand to bare metal.
Is it OK to use a DTM primer over the UMA spot primer, before applying topcoats of BM's MoorGlo acrylic latex? Would you tend to think 2 topcoats are necessary? I tinted both primers the same as the paint.
