Repairing Gauges Around Tub Surround - Painting - DIY Chatroom Home Improvement Forum
Old 02-26-2012, 09:39 PM   #1
Repairing gauges around tub surround
I'm attempting to repair uneven, jagged gauges around my tub surround that run 1/4" - maybe a little larger and a couple of 1/2" or so holes at the bottom. Should I use spackle, joint compound or caulk and spackle to repair? Also there was silicone caulk in the same area which I've removed most but there is some residue. Can I repair over the residue? Whatever the recommendatino, do I prime and what type would you recommend. Since the surround is outside the tub, not exposed to alot of water, would I use a latex caulk, which brand would you recommend? Thanks for any help
debbieindy is offline   Reply With Quote
Old 02-27-2012, 05:17 AM   #2
Debbie, even with all that info, I still haven't a clue what you're talking about. What are gauges? Pressure gauges? Temperature gauges? Just teasing. What type of substrate is your surround? A tub surround that is outside the tub is called a wall, is that what you're talking about?
Old 02-27-2012, 09:07 AM   #3
Too Short? Cut it Again!
Still not sure I understand but gouges are .25 to .5" long, deep or wide? .5 wide or deep would be stretching the limits of any caulk. In such cases I would use hot mud to fill the cavities. Finish joint between surround and wall with kitchen and bath caulk. If you have silicone you will have to dig it out. Nothing will stick to it or seal up to it. Not even more silicone.
K&B caulk has a biocide to prevent mold, algae, etc. You can prime/paint it.
Old 02-27-2012, 09:13 AM   #4
Rewards Points: 13,694
A picture would be real helpful.
1/8 ply behind tub surround? lucky6man Kitchen & Bath Remodeling 2 02-15-2012 09:38 AM
Tiled Shower Surround Help CluelessNewbie Kitchen & Bath Remodeling 4 02-10-2010 09:33 AM
Replacing and repairing a tub spout in a tub surround westhawk Plumbing 2 08-10-2009 02:07 PM
Gap in Corner Between Tub Surround and Bathtub? Howitzer Remodeling 12 09-17-2008 04:14 PM
Tub surround shower door issues Zharkov Plumbing 14 06-30-2008 10:52 PM
