Old 10-29-2006, 01:16 PM   #1
Question
repair area is still noticable
Hello,
I have a smooth ceiling in my kitchen.
I repaired a couple of areas, sanded and then touched up with the paint.
The problem is when i walk into the kitchen i can still see where i repaired. It is not like it is rough, but it not longer matches everything else. almost is shinny??
Do i need to re-prime it before painting?
will be glad to attach an image, if you do not know what i am talking about
thanks
paries is offline   Reply With Quote
Old 10-29-2006, 02:35 PM   #2
Home Improvement Guy
ron schenker's Avatar
I have a feeling you will have to prime and paint the whole ceiling to make it look good
ron schenker is offline   Reply With Quote
Old 10-29-2006, 05:40 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
Exactly how did you repair the spots on the ceiling?
slickshift is offline   Reply With Quote
Old 10-30-2006, 11:04 AM   #4
Ron
Man i hope not..... arg....
slickshift,
i put in some filler and then sanded. Then i painted that spot.
from an angle in the light i can see exactly where i sanded.
Old 10-30-2006, 12:01 PM   #5
They're all fixer-uppers
J187's Avatar
how did you go about matching the paint? Sounds like maybe you got a different sheen then whats on there.
J187 is offline   Reply With Quote
Old 10-30-2006, 05:25 PM   #6
slickshift's Avatar
Well, the actual type of filler could be the problem
Also the fact that you didn't prime the repair area could be the problem
That's what I get from your description
And I can't tell from here, but it's possible you didn't sand well enough
If it's just "flashing" (a sheen change over the repair spot), another coat might fix it
The proper way to do it is to spot prime repairs to avoid flashing
Often another coat or two can fix flashing
It depends on the paint
Old 10-30-2006, 08:50 PM   #7
ss,
I think what you have mentioned is the problem. I will sand more, then prime and paint a couple coats and see what that does.
Thanks for your help
Old 10-30-2006, 10:02 PM   #8
remodeling pro
The problem is beacuse of the touchup. The only way to get the paint on the patches to "read" the same is by having a uniform base under the finish paint. I always spot prime the repairs, then when dry prime the whole ceiling. If the repairs are indeed flat, they will not show throuigh the new paint job.
troubleseeker is offline   Reply With Quote
Old 11-01-2006, 09:12 PM   #9
Pro Painter
Does it seem as if that spot is smoother than the rest of the ceiling? Try 120 grit sand paper then paint. Even pre-used 100 grit.
joewho is offline   Reply With Quote
Old 11-02-2006, 08:37 AM   #10
J187's Avatar
Also, I try to feather out the spot I repaint a descent amount so it blends in better. If you sanded within a strict rectangle, you may be asking for trouble matching.
Edge of roof deteriorated, how to repair? (pics) diymonkey Roofing 3 06-23-2007 02:02 AM
What to do with area about tub surround? geowoman Remodeling 7 05-05-2007 02:56 PM
Need Sheetrock repair advice Giterdone Carpentry 6 02-03-2007 09:38 AM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 08:10 AM
