Old 02-21-2008, 01:38 PM   #1
Repainting A Steel Dock
I need to repaint a steel dock on a freshwater lake in South Carolina. There are some minor rust spots which will be steel brushed off and removed. I get lots of conflicting advise regarding what kind of primer and paint to use so I thought I would ask here.
What kind of primer and paint would you recommend for a long-lasting job ?
Duke76 is offline   Reply With Quote
Old 02-22-2008, 12:42 PM   #2
ihms683
I use one step rust neutralizer and metal primer bought at ca am supply 1866 848 9149 sand and clean
lwoodring is offline   Reply With Quote
Old 02-23-2008, 01:53 PM   #3
At least it's not saltwater.
Steel in a marine environment. I *can* say this is way beyond the world of house paint. You're now talking industrial level "coating systems" since you mentioned 'long-lasting' and, by inference, hi-quality.
'Tho painting is not my field - and I'm not at work - I do have access to industrial (oil refinery) coating specs.
I can recall this much:
These are 3 layers systems-- primer, mid-level, and finish. The system spec also has DFT numbers for each layer (dry film thickness) and yeah, they are measured in the field during application. What really complicates this tri-level matrix is that each layer may be a different brand and model number!
The only name I can recall is Carboline. If you go to their Website, look under marine/offshore, you will quickly realize that you are a long way from HD/Glidden-ville...
shasta37 is offline   Reply With Quote
Old 02-23-2008, 06:31 PM   #4
Master General ReEngineer
Bondo's Avatar
Ayuh,.....
Wirebrush it off,+ prime it with Rustolium Rust-oxide Primer,...
Then topcoat it with the Rustolium color of your choice......
Old 02-24-2008, 03:11 PM   #5
She'sapainter
I am a commercial painter wire brush very well I would even sand a bit as well I would also prim with a rust inhib I would look into a DTM or a aquapond Product Devoe makes both of thes products I am just not a fan of Rustoium products
A drop cloth isen't to catch paint, It's to protect what is under so wipe the drips as you go and don't track.
tverhoef is offline   Reply With Quote
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Repainting a New House 1simple Painting 8 12-10-2007 07:05 AM
How to butt wood stud wall to steel stud wall? Yorkergizer Building & Construction 3 12-01-2007 01:28 AM
A steel building that doesn't look like a steel building? MMW Building & Construction 1 06-11-2007 05:24 PM
steel under shingles orlockorlok Roofing 8 05-30-2007 09:44 PM
