Repainting A Sand Textured Bathroom Ceiling - Painting - DIY Chatroom Home Improvement Forum
Old 10-25-2011, 11:58 AM   #1
Repainting a Sand Textured Bathroom Ceiling
Hi...a corner of our bathroom ceiling has some water damage/stain from years ago that I would like to repaint. The ceiling has a sand texture and I will need to sand some of the water stain area as the paint is pealing. I just do not know how to tackle this since the water stain area will have little if any sand texture left after I sand it. Should I paint the whole ceiling with a textured paint to match? Should I just paint the part of the ceiling with textured paint where the stain was and the rest with regular white latex?
Any help or suggestions would be greatly appreciated.
Thanks.
wxologist is offline   Reply With Quote
Old 10-25-2011, 02:55 PM   #2
Gymschu's Avatar
Rewards Points: 236
It's up to you. If you're rather fussy about how things look, redo the whole ceiling. If it doesn't bug you too much, you can apply some sand-textured paint to your patched area and call it a day. If it were me, I would just redo the whole ceiling. Since it's a bathroom, it can't be too large of an area & won't take that much more of your time.
Old 10-25-2011, 05:18 PM   #3
ltd
Rewards Points: 536
are you talking bout a sand texture mixed into your paint ? if so put a small amount of sand texture in small amount of paint ,enough to go over bad area. let it dry then paint whole ceiling with the remainder of the paint that has no sand in it . if your talking bout the sand texture paint that is like thin out joint compound, same thing just go over patch let dry then paint whole ceiling with regular paint. then stand their and look at it and say look honey i did it p/s you have to seal in water stain for a small patch. you can use a rattle can of bin primer or its equivalent
ltd is offline   Reply With Quote
Old 10-26-2011, 05:14 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 140
[quote=ltd;756605]are you talking bout a sand texture mixed into your paint ? if so put a small amount of sand texture in small amount of paint ,enough to go over bad area. let it dry then paint whole ceiling with the remainder of the paint that has no sand in it . if your talking bout the sand texture paint that is like thin out joint compound, same thing just go over patch let dry then paint whole ceiling with regular paint. then stand their and look at it and say look honey i did it p/s you have to seal in water stain for a small patch. you can use a rattle can of bin primer or its equivalent[/quote]
There is no equivalent
Old 10-26-2011, 07:11 AM   #5
Rubbin walls since'79
Brushjockey's Avatar
You know Chris your kinda a black and white, no two ways about it kinda guy. Too much.
Insul X makes a pigmented shellac.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 10-26-2011, 05:12 PM   #6
chrisn's Avatar
Rewards Points: 140
In a spray can? If so, I did not kow that.I am really not so black and white, really.
Bathroom ceiling and walls HELP! Maia Painting 13 02-21-2013 04:21 AM
crack and stains in ceiling under bathroom diy_dude Building & Construction 0 08-06-2011 06:52 AM
HELP! Ceramic tiled ceiling in basement bathroom.... jrutherford Remodeling 1 10-11-2010 01:27 PM
Bathroom and textured ceiling painting? elementz Painting 6 10-01-2010 05:27 PM
finishing a bathroom ceiling mmhendrie Building & Construction 8 03-25-2009 04:01 PM
