Repainting previously painted concrete porch
You don't want to use an oil base product on concrete, as it will cause what's called saponification, its basically a reaction where the coating will not adhere and bond properly. Using a pressure washer is a good idea. You want to first clean the surface real well with a concrete cleaner, something with a degreaser in it. Then you want to scrape away all loose and flaking paint. If the concrete is smooth you will want to etch the surface with a concrete etcher. Their are several products you can use. I prefer to use Sherwin Williams Shercrete on exterior concrete surfaces. It is the same product I use on concrete decking around in the ground pools.
