Repainting Porch - Painting - DIY Chatroom Home Improvement Forum
Old 10-26-2007, 12:24 PM   #1
Repainting Porch
I want to repaint my porch. My plan is to sand down the area where the paint has already come up. Then I was going to put down a coat of primer, followed by 1-2 coats of paint.
Should I do anything else?
Is there any reason to sand the entire porch? I just want to get up anything that is loose so I figured I would do it in spots that need it.
Is there a sealant I should use to help protect it from the weather? I know they make sealants but I believe they are used for stained finishes.
Anything else I should do?
The high this weekend is suppose to be in the low 50's, is this adequate for painting?
Thanks for the help.
Willie5566 is offline   Reply With Quote
Old 10-26-2007, 08:58 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
What's it made of...wood?
Is it covered?
Does rain get on it?
slickshift is offline   Reply With Quote
Old 10-26-2007, 09:37 PM   #3
Is it covered?
Yes it is wood. It is currently painted. It does get rain on it, but is partially covered.
Old 10-27-2007, 06:00 AM   #4
Guest
Guest
Posts: n/a
You probably want to use an Acrylic floor paint and compatible primer. 50 isn't optimal by any means. An oil won't have enough time to dry before the temp drops. Some acrylics are good down to 35 degrees.
Sand enough to get all the loose off. It doesn't hurt to at least scuff sand the rest of it even if it's sound.
No Permit for my Porch and Deck jokiddjr Building & Construction 15 06-13-2007 10:34 AM
Repainting Columns on front porch R Parker Painting 10 04-17-2006 08:37 AM
PORCH - from BRICK to WOOD Kukurigu Building & Construction 1 11-12-2005 09:33 PM
Porch rebuild question Unregistered General DIY Discussions 1 11-26-2004 04:20 PM
