Old 01-16-2011, 03:47 PM   #1
Repainting over latex
Hello all, glad to be here! Im a complete home improvement noob who has enjoyed lurking and finally have a question of my own...
Moved to a new space and fixing up the old one, and the walls are a new scenario for me as there is peeling paint involved: Removed my auralex sound treatment foam that was stuck on the walls with FoamTak, and now using Goo-Gone to remove the excess glue. (It also removes latex paint, but that's fine as I promised I would patch, sand and prime the room anyway).
So there will be quite alot of peeling, melty latex paint; let me know if I've researched this properly:
-use goo gone
-scrape away glue and debris
-wash walls with sponge/warm water & let dry
-spackle any holes in walls
-remove peeling or excess paint as well as excess spackle and debris with a powered palm sander. This also roughs up the old paint so the primer will stick.(*Q:can this be sanded manually in a large room or is that an insane amount of wasted effort...
do most people do this with a powered sander?)
-wash sanding debris from wall and let dry
-tape, edge prime with brush, then roller prime the walls
Let me know if this sounds right, your expertise is much appreciated Thanks, and happy new year to you!
trupro is offline   Reply With Quote
Old 01-16-2011, 06:22 PM   #2
That procedure sounds about right - you may want to scrape the peeling areas, pole sand the entire walls, fill and then spot sand the fills. I only bring the orbital sander out for exceptionally bad walls.
Windows is offline   Reply With Quote
The Following User Says Thank You to Windows For This Useful Post:
trupro (01-17-2011)
Old 01-16-2011, 10:10 PM   #3
Matthewt1970's Avatar
I agree. A pole sander will do wonders.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
trupro (01-17-2011)
Old 01-17-2011, 04:53 AM   #4
nice, thanks! I'll get a pole sander for this week and if it works the rest of the room should be smooth sailing
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Repainting over flat white latex paint on drywall. etherag Painting 37 03-25-2012 04:21 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Help with repainting exterior latex hellothere123 Painting 3 08-17-2008 05:03 AM
Repainting over ??? Piney Painting 10 11-03-2006 04:12 PM
