-   -   Repainting over ??? (http://www.diychatroom.com/f4/repainting-over-4327/)
Piney 10-13-2006 05:17 PM
Repainting over ???
Greetings--
Room 1-- sheet rock walls. Old flat latex? paint underneath newer latex semigloss. We didn't put either of these paints on.
Top coat appears to peal off in small sheets-- like a piece of a balloon. Not all over but in places.
Its time to repaint it. I'd also like to add a bit of a light texture too.
Question-- what needs to be done to repaint this room with flat latex paint ? Sand off the old paint (and thus the wall texture) ? Prime is, texture it and paint , or ???
Room 2- sheetrock walls with semigloss laytex paint on them.
QUestion- Can I just paint over these with flat latex paint or do I need to prime them ?
Room 3- Sheetrock walls with a HEAVY!!! swirled texture, covered with bright red gloss latex paint.
Question--How does one go about removing this obnoxious texture and repainting this room (and ceiling) ? Sand down to sheetrock, retexture and paint ? Rip out all sheetrock, replace ect ?
Room 4- sheetwork walls once covered with glued on Formica panels. Removed formica panels, but this left surface paper tears on sheetrock.
Question-- Can I roll on a texture, then paint these walls or will this require a replacement of the Sheetrock ?
slickshift 10-13-2006 08:36 PM
Originally Posted by Piney (Post 20738)
Room 1--
Yes
Remove all the loose paint you can
Sand if needed
prime with a problem-solving primer
Texture/Prime again (depends on texture)
Paint
Cleaning and a nice scuff sanding will suffice
Scuff sanding means a light sanding to give the new paint something to hold onto
Hard to say if there's another choice w/o seeing it, but prolly re-rocking it is the best (or only) choice
You can prime with a problem solving primer (in this case I'd recommend Gardz), then fill in the repair areas with joint compound (it may take more then one coat), sand smooth, prime the repairs (regular primer will work for this step), then paint
Paintguy26 10-13-2006 09:51 PM
picturing this house in my mind is making me go nuts:wallbash:
Piney 10-13-2006 09:59 PM
1 Attachment(s)
Here's a pic of the heavily textured wall . Its the best one I've got, although it might not show much. The texture was troweled on to cover gouges left in walls from removal of panneling. Its pretty thick, "swirley" texture. Its on the walls and ceiling in this bedroom and the hallway ceiling too. We didnt do it... realy...LOL
I guess it would be too much sanding. Other posts suggest wetting this texture and scraping it off, then sanding and retexturing. Its a glossy paint on the surface so that is probably not the answer. I'm afraid that replacing all the sheetrock may be the answer--but thought I'd ask folks first
*sigh*
Piney 10-13-2006 10:01 PM
And.. its not even your property LOL
Old house with little (ok NO...) cosmetic upkeep by the previous owners.
Paintguy26 10-13-2006 10:06 PM
Hey, at least you've found a good resource to help you out....we'll try our best. I got a bit overwhelmed by all the questions all at once. You can trust slick though. I would just be repeating what he said, so that's why I made a 'funny' instead....:wink:
Piney 10-13-2006 10:13 PM
I read over some info on the Zinzer web site. With regard to the Room # 4--Their info implies to skim cost the entire wall. Is your suggestion to skim coat the entire wall or just over the torn spots ?
Thanks again for the info !
Paintguy26 10-13-2006 10:23 PM
You could skim the wall, are you good with mud? You need at least an 8" knife or taping knife. Thin coats is the key. You want to put the mud on in sheets to avoid too much sanding. Also, if you put the mud on too thick, it could crack from shrinkage. At this point, this sounds like the logical thing to do. I suggest doing a search on the net that shows you step by step pictures of this project. After all, you want it to look half way decent when it's done...:thumbsup:
slickshift 10-13-2006 10:35 PM
I wouldn't skim the entire wall unless I absolutely had to
I'd def. try and just do the torn areas
But that depends on how much/how bad it is
...and mudding isn't one of my strong points
The good mudders, I can see why they would just do the whole wall
joewho 11-02-2006 09:18 PM
You're being stuck with a few rooms of crap. Everything to make this the most difficult work has been done. Just tell the HO that they all need new drywall. Drywall on top of the formica and tear out the drywall on the other rooms.
You're headed for headaches that you won't get paid for in the end.
However, the red walls can be sanded with 80 grit to break through the paint, then saturate with water to get the mud wet. It will scrape off easily. But that leaves you with junk, just like the last guy who tried to cover it up with texture. Might be easier and better to just tear it out and fresh drywall.
Tmb9862 11-03-2006 04:12 PM
For the room with the texture if it was my house I'd replace the sheetrock. If it was a customers house I'd recommend they do the same.
Seeing as how it seems this isn't your house though I wouldn't spend the money. I'd just run over it quick with some sandpaper, skim it, sand it, and repeat until it's smooth. When you skimcoat thin out the mud, don't try to use it at the thickness they leave it at in the bucket. Another option is to get 1/4in sheetrock and put it right over what you have now. I've seen this done before and if done right it looks good and holds up. Just mind the moldings and outlets with this one.
