Repainting Laundry Room - Painting - DIY Chatroom Home Improvement Forum
Old 10-13-2006, 09:52 AM   #1
I am getting to repaint my laundry room. It's currently a light yellow and I'm not sure what color I'll be going to but if it's a darker color do I really need a primer?
What exactly is primer other than to cover up the old color?
What brand name paints/primer would you suggest?
Thank you for any advice you can offer!!
cloverxxo is offline   Reply With Quote
Old 10-13-2006, 12:24 PM   #2
primer helps the paint adhere to the surface.
redline is offline   Reply With Quote
Old 10-13-2006, 08:22 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
No
Sometimes a grey primer can help if you are doing a real red or deep blue because those are tough colors to paint
Mostly DIYers tend to over-primer...primer when it's not needed
Actually, it's very rarely used to cover up the old color
Only on drastic color changes
The actual purpose of a primer is to seal the substrate (wall or whatever is being painted) and help the paint adhere to the surface
Not to cover up the old color
Most brands have different "lines"
The rule of thumb is (and I have found it to be very true):
You get what you pay for
You can't go wrong with most of the Ben Moore or Sherwin Williams premium paint lines, and Zinsser's primers
But it really depends on exactly what you are doing as to what the best product is (and who makes it)
There's no "Brand X makes the best primer and paint for everything" type of thing going on
slickshift is offline   Reply With Quote
Old 10-13-2006, 10:00 PM   #4
Painting Contractor
This is one of the most confusing aspects DIY'ers or Customers ask about. When you have a wall with paint on it, as long as it's in good shape, you dont need to prime. You sand the wall, wipe it, and apply paint.
I suggest Sherwin Williams primer and paint. I use this paint all the time exclusively. Benjamin Moore, Zinsser, Pittsburgh are all good. Shy away from Behr, Olympic, Glidden, Ace. They will only create more work...
"The measure of success is not whether you have a tough problem to deal with, but whether it is the same problem you had last year". ~ John Foster Dulles
Paintguy26 is offline   Reply With Quote
Old 10-14-2006, 08:03 AM   #5
Thank you!
That is just what I needed to know!
Upstairs Laundry Room Install Matt Burks Remodeling 3 08-22-2007 12:12 AM
occasional sewer gas smell in laundry room nebben Plumbing 3 03-25-2007 11:35 AM
Supply and Return from Laundry Room bjstewa HVAC 7 03-03-2007 12:39 AM
Replacing a laundry room roof. Tomcat1066 Building & Construction 5 11-11-2006 04:08 PM
stabilizing floor in laundry room waterlily_girl Carpentry 3 03-02-2006 01:59 PM
