Repainting Kitchen Cabinets - Painting - DIY Chatroom Home Improvement Forum
Old 03-07-2010, 02:56 PM   #1
I live in a manufactured home. The cabinets are cheap pressed something or other (not wood). I painted them once with a water based paint. It's has tiny peeling spots in some areas but isn't too bad. I want to paint over that paint now. Do I need to primer it, with a water base primer first, then paint with another water based paint? I'm just an old granny trying to take care of things myself.
handy granny is offline   Reply With Quote
Old 03-07-2010, 06:02 PM   #2
jlhaslip's Avatar
Rewards Points: 980
if it is peeling, you will need to sand them and re-prime.
Check out Zinsser for a water-based primer.
Use Melamine paint for your top coat. It is available in a water-based mixtures well.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 03-07-2010, 08:48 PM   #3
I appreciate your help!
Old 03-08-2010, 06:39 AM   #4
Too Short? Cut it Again!
Ditto except for that I am not sure about the melamine suggestion. It does give a nice hard finish but I find that it chips too easily and the chips are hard to surface out later.
You need to degloss the current finish with either sandpaper or a chemical deglosser.
Kitchen cabinets - Are Ikea cabinets good? What other mfgs have you used? whataboutj Kitchen & Bath Remodeling 24 11-09-2012 07:14 PM
Painting Kitchen Cabinets, Back wall NewlywedKristin Interior Decorating 12 03-18-2010 11:23 AM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-21-2008 12:32 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 11:23 PM
