Repainting The House This Year - Painting - DIY Chatroom Home Improvement Forum
Old 07-13-2008, 08:36 PM   #1
Rewards Points: 156
Repainting the house this year
I am planning on repainting our house this year. It was built in the 1960's, has red cedar shakes for siding. It has several coats of paint that I can tell, the original has lead in it. The most curent coat of paint was done by the previous owner about 5 years ago according to our neighbors. My question is regarding alligator type cracking on some of the shakes. These cracks in the paint are not peeling, but are definately cracking.
Will these cracks cause grief shortly down the road after painting the house? I plan on using A 100 Sherwin Williams oil based primer first, then latex Superpaint over that with 2 coats. My fear is that after painting the house these cracks will come back to haunt me and force me to repaint the house in a few years from now. Any ideas or comments would be most appreciated. Would 2 coats of primer help in this case? Becuase of the lead in the paint, removing the paint is out of the question as far as I am concerned.
Repainting the house this year-100_1963.jpg   Repainting the house this year-100_1967.jpg
creamaster is offline   Reply With Quote
Old 07-13-2008, 10:00 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
You've got issues due to multiple coats of paint of different types
I would not prime...and not oil prime especially
Assuming this last coat was latex, you've got enough oil/latex layers...and they are probably the cause of your cracks
The "best" cure would be a full strip and proper primer and re-paint
As there is lead involved, it is not a DIY project, and professional certified technicians must be hired
Again assuming a latex top coat, I would alternately suggest a high build exterior paint such as SW Duration or BM Aura
The high build paints such as these will fill in the cracks, and allow for a few more years of using the existing siding
Again, unless needed for bare wood spots, do not use a primer
If needed, do not use an oil
slickshift is offline   Reply With Quote
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
Hello. I moved my house... shtoink Introductions 10 06-25-2008 02:40 PM
"New: House, and need some advise... dcd22 General DIY Discussions 9 06-17-2008 08:12 AM
Old wooden supports in basement of 2 family 100+ year old house ytorrie Building & Construction 2 06-03-2008 07:31 PM
Will my house make my kids sick??? jokrupinski General DIY Discussions 18 09-29-2006 05:05 AM
