Repainting Ceiling - Spotty From Primed Touchup - Painting - DIY Chatroom Home Improvement Forum
Old 02-10-2013, 10:22 AM   #1
Repainting ceiling - spotty from primed touchup
I reprinted my ceiling with a flat ceiling paint but a few spots from water or soda?? Was not covered up so I applied bullseye123over those areas then put another oat of ceiling paint on it and now those areas are shinny...any suggestions would be appreciated
Update, I applied a second coat and all is good now.
tmccasland is offline   Reply With Quote
Old 02-10-2013, 02:39 PM   #2
Gymschu's Avatar
Rewards Points: 842
Anytime you use a stain blocking primer you will get those shiny spots. Most of the time the spots are just taking longer to dry and cure, but they do go away. Sometimes they DON'T go away. Well, anyway, I see you solved your problem.......well done.
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
replacing a 7'6" ceiling for a Split-foyer home czellerhoff Building & Construction 1 10-16-2010 11:36 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Touchup on Popcorn Ceiling TheNewGuy Painting 3 10-23-2009 04:05 PM
Popcorn Ceiling Repair CecszaR Painting 7 08-28-2009 03:37 AM
