Repainting Bathroom - Painting - DIY Chatroom Home Improvement Forum
Old 02-19-2012, 07:26 PM   #1
bryanp22's Avatar
Rewards Points: 294
Repainting bathroom
Hi,
Just bought a house a few months ago and now want to repaint the bathroom because of a leaky pedestal sink that we are replacing. Do I need to do any special prep because of the paint used. They used a behr kitchen and bathroom paint before. It just seems glossy and washable so I am not sure if I need to do for prep.
bryanp22 is offline   Reply With Quote
Old 02-19-2012, 07:51 PM   #2
Too Short? Cut it Again!
You want to make sure you wash it all thoroughly and take some Clorox to it if there is algae or any such things anywhere. You should scruff it up a bit with a deglosser or some sandpaper.
Carve out any old caulk you want to replace around the tub, shower door etc. Re-caulk. Remember, silicone is not a caulk.
Change out or add any toilet paper holders, towel racks, robe hooks and so forth.
I would put two coats of semi-gloss back on it, especially if it is a small bath you will need to wipe down now and then. Of course you know not to use BEHRly paint or any other box store brand this time!
Old 02-19-2012, 08:42 PM   #3
bryanp22's Avatar
Rewards Points: 294
Yeah the prior home owners relied completely on Behr paint. So far we've been using Sherwin Williams paint as we've been repainting. It's a few blocks away and the staff has been helpful so far.
Old 02-20-2012, 03:16 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 504
Semi gloss on the walls is over kill,imo, eggshell or satin would be a better choice. Semi looks like a hospital room
Old 02-20-2012, 05:20 AM   #5
Learning Things Every Day
Jay 78's Avatar
How does it look? Any problems with it?
Under Construction
Jay 78 is offline   Reply With Quote
Old 02-20-2012, 06:49 AM   #6
Not wild about the look of semi but for trim myself but in old, small, bathrooms with poor ventilation it seems to stand up to the humidity and moisture better over time.
Old 02-20-2012, 07:42 AM   #7
bryanp22's Avatar
Rewards Points: 294
The behr looked fine except where they went like an inch on the ceiling in one spot. They had covered the back on the sink basin in silicone and just used wall anchors to mount it on the wall do I have to add a backer board and fix the wall.
Old 02-20-2012, 04:22 PM   #8
chrisn's Avatar
Rewards Points: 504
Won't argue that
Best option for Bathroom Ceiling Paint? tealab Painting 7 04-05-2013 04:49 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
gutting bathroom debiasio Remodeling 30 02-17-2011 02:32 PM
Basement Bathroom Circuit PJ33P Electrical 1 02-12-2011 07:13 PM
Bathroom tile question aumanpj Building & Construction 66 07-18-2009 11:43 AM
