Repainting Aluminum Siding - Painting - DIY Chatroom Home Improvement Forum
Old 05-10-2013, 05:38 AM   #1
smikes's Avatar
repainting aluminum siding
Aluminum siding paint is chalking and coming off. I am thinking powerwash , scrub with a scour pad rewash and prime/paint.
What should I use to wash, and what should I use for primer/paint?
Any primer -paint combo that will adhere well?
also
I am planning on buying a sprayer, one that I can use with a 5 gal bucket.What is a good one in the 200-300$ price range?
Honey-do list is quite long this year............
Thanks for your help!
smikes is offline   Reply With Quote
Old 05-10-2013, 05:52 AM   #2
Rewards Points: 13,960
I'd clean it with TSP, rince off well and use Sherwin Williams Duration or Super paint.
There is spray painer in the $300.00 range that would be worth buying to paint a whole house.
Unless you know how to spray I'd stick to a roller and a 2-1/2 sash brush.
Your going to spend more time learning how to use it, masking, cleaning it then it's worth.
Old 05-10-2013, 06:48 AM   #3
Gymschu's Avatar
Rewards Points: 930
THere are literally dozens of threads on "painting aluminum siding." You will find all the info you would ever need by doing a "search" on here.
Here's just one example: Another Aluminum Siding prep question
Gymschu is online now   Reply With Quote
Old 05-10-2013, 08:12 AM   #4
Too Short? Cut it Again!
Many threads on cheap sprayers too. If you only need one for this project, rent a highend model. Don't buy a lowend, mostly plastic, toy garage ornament.
As for primer? Has the aluminum siding paint peeled completely off and you have oxidation of the metal to deal with? If so, you will want to get all that off and TSP will not do the trick. Aluminum Naval Jelly comes to mind but it is expensive in small amounts. AI fine wire brush comes to mind too.
Once the oxidation and effluence is out of your way, a quality self-etching primer for aluminum should be in your project plans.
Copper roof & aluminum siding Marcia Hamilton Roofing/Siding 4 04-24-2012 10:36 PM
Best Primer For Aluminum Siding? dignan07 Painting 17 07-29-2011 09:57 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
