Repainted Wall Around Bullnose Corner... - Painting - DIY Chatroom Home Improvement Forum
Old 12-09-2010, 02:58 PM   #1
Repainted wall around bullnose corner...
I recently repainted a single wall (accent wall) in our home and happy with the result. This wall has a hallway that leads into the master bedroom with a bullnose edge corner (rounded). I taped off the edge so I would get a clean break between the old paint and the new.
Anyways, after removing the tape, the edge looks great - no paint leakage (used Frog Tape). My only observation is that the new layer(s) of paint are higher than the old. What I mean is, that I can visibly see a difference in height where the new and old paint meet. I'm guessing it's because I used several coats, re-primed and painted 2 more coats because I wasn't happy with the first color choice. I can feel the edge with my fingernail.
Should I be concerned with this, or not even worry about it? I thought maybe I should try to sand it down to blend that edge in more, but I don't have a clue on how to go about that, and I would most likely just make it worse.
Any ideas or comments are welcome.
Thanks.
dbell is offline   Reply With Quote
Old 12-09-2010, 03:49 PM   #2
Contractor
Sasquatchpaint's Avatar
If the line is straight and there was no bleading reach around and pat yourself on the back! You could sand it down and redo both colors but even when you don't dislike the first color you get a little edge when using tape like that.
BTW 95% of the time you don't need to prime to change colors or repaint your walls as long as both of the paints you're using are latex.
Sasquatchpaint is offline   Reply With Quote
The Following User Says Thank You to Sasquatchpaint For This Useful Post:
dbell (12-09-2010)
Old 12-09-2010, 03:54 PM   #3
40+yrs Paint Trades
Don't touch it. Leave well enough alone.
hoz49 is offline   Reply With Quote
The Following User Says Thank You to hoz49 For This Useful Post:
dbell (12-09-2010)
Old 12-09-2010, 04:02 PM   #4
Contractor
Yea, what he said! (just in case my origional post danced around the question too much!)
Old 12-09-2010, 04:13 PM   #5
Thanks Sasquatchpaint - I appreciate your comments. I think I will leave it alone. It looks good overall, was just curious about that edge, though I think whenever you use tape like that, you are bound to get a small edge. Mine is a bit more noticeable because of the amount of coats I used.
BTW, I wanted to use primer because I was going from a darker color to a lighter color. Also, I had glazed the wall previously and had to wipe it all off. I needed a good primer to make sure things stuck If you look back several posts you'll see a thread about glazing a wall. I ended up redoing that wall - didn't like how it looked.
Old 12-09-2010, 04:21 PM   #6
Contractor
Your faux finish wall in the other thread looks awesome!
Old 12-09-2010, 04:35 PM   #7
Thanks, though that's the wall I just repainted. It looked pretty cool, but the glaze wouldn't dry. Had to basically start over on it.
Old 12-09-2010, 07:31 PM   #8
Rewards Points: 258
Hey dbell,
At the bottom of the wall try taking a piece of sandpaper with the sand facing up. Put your hand on the sand with the paper on the paint. Just rub the paper over the line in the paint. This should take the edge off the line without polishing the edge. If it looks OK, then do the rest of the line. Don't get over zealous with the rubbing, just a little should do it.
Steve
www.handpaintedbysteve.com
spraygunn is offline   Reply With Quote
Wall construction for insulation support WillK Building & Construction 3 12-09-2010 01:55 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Mounting Corner Wall Mount Sink petedickson82 Plumbing 2 02-17-2010 09:28 PM
Repair damaged bullnose corner DRCollier Building & Construction 2 07-15-2007 09:46 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
