Old 05-26-2007, 04:41 PM   #1
Super Moderator
Floorwizard's Avatar
Default Repaint my deck
Whoever painted the deck before I purchased it did a bad job. After the paint gets even just a tad moist from rain it starts to peel. So now I have alot of bare spots like such....
So I have decided to use my power washer and blast this stuff off my deck. But I am wondering if this is a good idea. I would like to know just how bad a mess this will make. I am sure there will be some seriouse paint chips all over, and there are rocks below the deck.
I just want to get this paint off and repaint later this summer.
Any recommendations?
Time to ride again!
Floorwizard is offline   Reply With Quote
Old 05-26-2007, 05:19 PM   #2
Home Improvement Guy
ron schenker's Avatar
Looks likes there's no primer under the paint, that's why it's peeling off. Power washing will get most of it off depending on how many PSI you've got. and it will make one heck of a mess below. You might want to consider sanding it all down, then priming and painting. If you decide to pressure wash, you can always cover up everything below with some 6 mil. poly or drop cloths to help collect all the flying chips of paint. From the pictures, the rest of the deck paint looks to be in good condition. Is the wood pressure treated?
ron schenker is offline   Reply With Quote
Old 05-26-2007, 05:27 PM   #3
jms
florcraft
If you are worried about the mess power washing may cause then you
may be better off using a sander and scraper to get loose paint off your deck. just remember just because you powerwash does not mean
you won't have to sand and scrape after. the key is in the prep work
this may take a little longer than you may think, but is well worth the time.Take your time and do it right.
jms is offline   Reply With Quote
Old 05-26-2007, 05:51 PM   #4
poppameth
Guest
Posts: n/a
I'd use a stripper on it like Flood Powerlift. Hitting it with too much pressure from your power washer will tear up the wood. And you'll probably need a fair bit of pressure to get it all off. With the stripper to lift it first, you can use a bit less pressure and avoid tearing the wood up so much.
Old 05-26-2007, 06:16 PM   #5
Super Moderator
I do not know.
I am confident that I will need to sand and scrape eventually. I am just sick of it raining and having peeled paint stuck to my shoes. It comes off with minimal pressure.
I thought about that, but I figured 6 mil poly will be like a swimming pool full of paint chips eh?
But what else to do.....
Time to ride again!
Old 05-26-2007, 06:49 PM   #6
poppameth
Guest
Posts: n/a
Put down some mesh, like garden netting. It'll let the water pass through but catch the paint chips.
Old 05-26-2007, 07:13 PM   #7
jms
Originally Posted by Florcraft View Post
I do not know.
GET ON WITH THE WORK!
Things don't happen by them self. Try putting some runners down. while talking about it.
take care
jeff
Old 05-26-2007, 09:07 PM   #8
Super Moderator
Actually part of the deck is done.
windy real bad right now which is making the paint chips fly too far.
will try again tommorrow.
Time to ride again!
Old 05-27-2007, 07:03 PM   #9
Tired, Cold, and Damp
slickshift's Avatar
Thin canvas drops to catch the chips
They'll get damp but water'll soak through
Powerwash anything off that will come off
Sand the rest
If you guys have one of those floor machines with the metal mesh grinder screens for concrete floors (I think it's used mostly for prep, sorry, the technical term escapes me-but being in flooring maybe you've seen/have them), well they've got screens for decks too
You'll have to set all the nails (they don't like nails), and it goes a bit slow, but it works
If you don't have enough left to warrant that, then scrape off the rest
Use a good scraper, I'd suggest Hyde's 2 1/2" Maxx Grip Tungsten Talon Heavy Duty Carbide Scraper, (and 2 Edge Blade)
It frikin rocks
Rotary sand what's left (if at all poss. but a random orbital will work also...just not as well for this job)
Do not "paint" the deck when the time comes
If you want a solid color, get a solid stain
I'd recommend Behr
Bwahahahahahahahahahahahahahahahaaaaaaaaa!!!!!!!
J/K
I'd recommend Sikkens or a comparable quality
slickshift is offline   Reply With Quote
More On This Topic
Pedicure Equipment & Tools
Pedicure Equipment & Tools by Expert Village
Hi! I'm Lillian with Expert Village and I'm going to show you the supplies that you'll need to do a do it yourself pedicure. First you would need a towel to put underneath the basin that you would be soaking your feet in. That is just to protect the... Read More »
How to Power Wash a Patio
How to Power Wash a Patio by Expert Village
Hi this is Peggy Charlton for Expert Village I also had this I found under the sale in a town on the way to a school event we stopped and I grabbed this it was real cheap and I painted red. And all this red matches and ties it all together perhaps your... Read More »
Hi! This is Peggy Charlton from Expert Village. Another example would be about high school baseball and this is by Erica Millin from the Houston Chronicle. As dramatic as high school sports can be, sometimes the more intense battles involve the students... Read More »
Hi. I'm Paul Popplewell, with Central Equipment Company. I've been employed with them for 18 years. I'm here today to represent Expert Village. After we've sharpened our blades, we want to clean the deck and make sure it's ready to be stored for the... Read More »
You put a lot of effort into that beautiful new deck, so the last thing you want is to see it become a victim of the natural processes of the weather and environment. To prevent that from happening, weatherproof your deck before breaking out the deck... Read More »
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 09:12 PM
deck - beam to post connection (??) brocasArea001 Carpentry 17 06-26-2007 11:54 AM
deck questions robphelan Carpentry 6 06-25-2006 08:42 PM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 11:50 PM
deck walls maintenance Building & Construction 6 04-04-2005 12:37 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
