Repaint Deck - Painting - DIY Chatroom Home Improvement Forum
Old 04-13-2009, 04:59 PM   #1
repaint deck
I need to repaint my deck. I went to Home Depot, Lowes etc and got different advice. One person suggested that I use a stripper, but another person said that I should not use a stripper (since I have a toddler at home) and instead use pressure washer instead.
I am attaching some pictures. Can someone also recommend if I need to use some filler, because I can see cracks in the wood surface.
Will appreciate your inputs.
Thanks in advance
repaint deck-pict2619.jpg   repaint deck-pict2620.jpg   repaint deck-pict2621.jpg   repaint deck-pict2622.jpg
firsttimers is offline   Reply With Quote
Old 04-13-2009, 05:22 PM   #2
Same color, different color?
Do not try to fill the cracks, it won't last long
Old 04-13-2009, 05:26 PM   #3
Same color (white) is OK. I want to do a good job, so that I dont have to do it again and again.
Old 04-13-2009, 05:33 PM   #4
It's paint & exposed to the weather
You will have to do it over & over again
The deck at my last house was pretty beat up
I just used a sander & scraper
I used solid stain - maybe 2-3 coats as it was dry
I did give it another coat at some point in 7 years I lived there
Old 04-13-2009, 09:26 PM   #5
Matthewt1970's Avatar
Rewards Points: 1,098
That sure looks like latex stain/paint to me. I would get it all off the deck and then use an oil based stain.
Old 04-14-2009, 05:03 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
There in lies your problem. Go to a REAL paint store for advise
chrisn is online now   Reply With Quote
Old 04-14-2009, 07:01 PM   #7
repaint deck
Thanks for your suggestions. Can you tell me
1. whether I should use a power washer to take out the paint or use a stripper.
2. Should i try to sand it in order to smoothen the wood OR is it not worth it?
3. Finally I hear that staining is better than painting? Do you think it would be a good idea to stain or should I only consider repainting?
Like always, thanks for your suggestions
Old 04-21-2009, 11:56 PM   #8
looks like you have quite the project! How old is the deck and what type of wood is it? I did a deck that was in pretty rough shape and I tried everything. I would first apply a stripper to a small area and then power wash or brush it out to see if it works. If it's successful then try the whole deck and maybe you will have to sand it afterwards. For staining, in particular using a semi solid stain, the wood needs to be able to absorb the stain - that means getting rid of all the crap that gets in the way of this occurring. I am really unsure of what would happen if you painted over that, if it would take or how long it would stay - hopefully somebody else knows!
jellydonut is offline   Reply With Quote
Old 04-22-2009, 01:27 AM   #9
Faron79's Avatar
Rewards Points: 260
Haul out the "Rental" sander!!!
Oh my...that deck needs some help!
My deck is a 12 y/o Redwood deck; west-facing; NO shade; in Fargo, ND...temps from -35 to +100 occasionally.
Above: Sanding in progress on the skirtboards and spindles...G*D help me...
Below:
Lower steps sanded the day before and stained. Again...this is 12 y/o Redwood!
Used Sikkens SRD Redwood, #089.
My stain of choice...
Used a Porter-Cable palm-sander on the steps, spindles, etc., last summer '08. Went through a bunch of 60 & 80-grit paper!!! Even used some 50-grit for the skirtboards that faced west. Then went over with 60-grit, and a light pass with 80.
Two years previous, rented a 12" x 18" Vibrating-plate sander to do main deck floor.
THAT is what you'll need to do for the floor.
Faron
Faron79 is offline   Reply With Quote
Old 04-22-2009, 09:21 AM   #10
I would rent a power washer and basically strip most of the existing paint off. I would then use a random orbital and sand everything until you get a surface that is comfortable for walking barefoot. Don't skimp on prep work this is the most important. Now you're ready for stain.
However, I would like to say that pressure treated will always check and is not the greatest wood to hold paint. Maybe in the future you should think of replacing it.
waynech is offline   Reply With Quote
Tags
decks , paint exterior
Post detail for raised covered deck jogr Building & Construction 3 05-16-2009 08:46 AM
Extend House Roof Over Back Deck Justahome Carpentry 17 04-05-2009 04:42 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Roof used as a deck - what is a good approach rogersor Roofing/Siding 3 09-19-2007 02:05 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
