Repaint Damp Steps Down Hillside? - Painting - DIY Chatroom Home Improvement Forum
Old 06-19-2011, 03:17 PM   #1
Repaint damp steps down hillside?
I have old steps going down the hill from one part of my yard to a lower part. They follow the slope so the bottoms of the steps are inches from the dirt. After we owned the place a few years, the paint was wearing off, so I went to a big box store and did what they told me: scrape, wash with bleach (to kill green mold), rinse, dry, coat with their primer, then their exterior latex. Two months later the new paint was cracking and peeling. Over the phone the paint company's technical expert said we should scrape and then repaint with their exterior oil-based paint. Now that paint is peeling off in long strips, and in a few places where water got under blisters and strips of peeling paint, the wood is now actually rotting. What should I do next? Thanks. Dave
davereed is offline   Reply With Quote
Old 06-19-2011, 03:57 PM   #2
Learning by Doing
Leah Frances's Avatar
Paint on stairs has a hard enough time inside. I can't imagine trying to keep it up outside.
If it was me.... I'd stop buying paint, save my money and replace with pressure treated or (god forbid) Trex or the like.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 06-20-2011, 08:18 AM   #3
Too Short? Cut it Again!
You can use a porch and floor paint, not a primer/semi or whatever the box store talked you into mix. This will be constant though and you might want to mix some sort of anti-slip agent into the paint. Painted steps and damp conditions sound like a broken leg or hip in the making.
Old 06-20-2011, 08:34 AM   #4
Learning by Doing
to anti-slip something/anything on outdoor steps.
I've painted a covered porch with the best 'porch and floor paint' I could get. I stripped down to bare wood, primed with alkyd, applied two coats of paint..... and in the heavy traffic areas of the porch three years later it still needs some new paint.....
Old 06-20-2011, 08:55 AM   #5
Leah Frances and sdsester, thank you! Dave
Damp Insulation in Attic wiz561 Building & Construction 6 12-23-2010 11:16 PM
Adding exterior drain with concrete steps in way steveel Building & Construction 5 09-10-2010 04:23 PM
Exterior Wood Steps with Fieldstone Risers Leck Building & Construction 1 06-29-2010 08:32 PM
Re-staining inside steps saggdevil Painting 10 09-20-2009 06:40 PM
wood front porch steps dlhein Carpentry 4 05-11-2008 08:06 PM
