Removing Wallpaper And Then Painting - Painting - DIY Chatroom Home Improvement Forum
Old 07-23-2006, 02:28 PM   #1
Removing wallpaper and then painting
Hi -
I just joined.
I have had to remove wallpaper in one of our bathrooms and have some questions.
First -- do I need to remove all/most of the glue reside before I paint?
Second -- I having a hard time with the areas behind the toilet and sink. I suppose I have to temporarily remove them before I can finish?
Susan
applesusan is offline   Reply With Quote
Old 07-23-2006, 03:15 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Hi Susan
Welcome
First: Yes, you should remove as much as possible
If it was properly applied, you should be able to remove it all
If not, you really need to do the best you can
If you can't remove it all, then use a specialty primer such as Gardz, which is meant to go over the residue
Second: It may be helpful to remove those items to work around them, but you shouldn't have to
Technically as a painter I'm not supposed to remove them, nor would my ins. co. want me too, so I always work around them
But I certainly would've appreciated removal in many situations
slickshift is offline   Reply With Quote
Old 07-26-2006, 09:32 AM   #3
Fixing a a wallper removal mishap
Thanks Slickshift --
I removed the drywall in two steps. First I peeled off the outer "waterproof" layer which was pretty easy to do Then I dampened the backing and peeled it off. Since I mostly didn't use a scraper, much of the glue stayed on.
Then I had to rewet the wall to scrape the glue and then wipe it down. But some glue was still on the walls. So I let it dry well and used a sponge sander. This seemed to help.
Unfortunately, someone who was "helping" remove wallpaper with a scraper also removed a huge chunk (about 11x27 inches) of the drywall outer layers down to the cardbard-like center. (His "help" was my inspiration to find another way to remove wallpaper)
It seems to be a bigger area than I can cover with compound. I mean, I can cover it it with compound but I don't know if I can sand it to look flat.
Do I do the best I can with compound? Or do I cut out the affect piece and replace it? I'm in the process of trying to fix it with compound but any suggestions would be gratefully accepted.
Susan
Old 10-01-2006, 09:28 PM   #4
Rewards Points: 530
Good guestion. I have no doubt I could float this area out okay, but I do wonder which way is best. Maybe this will bump this post up and Slick, Pro or someone will respond.
Old 10-02-2006, 05:36 AM   #5
slickshift's Avatar
If you can skim (skim coat joint compound); then prime with Gardz, skim, sand, prime the skimmed areas (regular primer), paint
Old 10-02-2006, 06:31 AM   #6
Painting Contractor
Originally Posted by applesusan View Post
Hi -
I just joined.
Susan
Most definitely, yes, you should remove 'most' of the residue. I say most, because some is just too stubborn to come off. These stubborn areas simply need sanding and priming with a good primer/sealer. I like zinsser products personally. I have never had to remove anything when removing wallpaper. I usually am able to score, spray, and scrape it good enough to work with it. And yes, I always have a bucket of easy sand around for the 'mistakes' that happen regularly But, that's just me~I've become very proficient at wallpaper removal and have come across many different issue/problems. I have also used both liquid removers, and steamers~
Keep an eye open for a before/after of a HUGE wallpapered foyer I'm working on...I'll post pics asap
"The measure of success is not whether you have a tough problem to deal with, but whether it is the same problem you had last year". ~ John Foster Dulles
Paintguy26 is offline   Reply With Quote
Old 02-16-2008, 07:26 AM   #7
Cool
color washing
Hi my name is Terry and I'm new to this.
I'd like to know how much paint and glaze to use for colorwashing a wall.
rdugan is offline   Reply With Quote
Old 02-24-2008, 04:32 PM   #8
She'sapainter
If you have to do another room try using a tiger paw and a wall paper remover solution and let it stand for about 10 min it normally comes off with out a fight
A drop cloth isen't to catch paint, It's to protect what is under so wipe the drips as you go and don't track.
tverhoef is offline   Reply With Quote
