Removing Wallpaper - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-08-2009, 01:27 PM   #16
Rewards Points: 12
I am in the process of doing one of my bathrooms right now and have the paper off and getting ready to use zinser gaurds for primer. I bought a steamer from HD for around 50 bucks and it seemed to work good. Just hold it on a spot for about 20 seconds and then use a plastic putty knife to remove it. Got most of the glue and everything off. I think it was worth the 50 bucks I paid. Like mentioned above you need lots of patience when removing wall paper. Good luck.
ponch37300 is offline   Reply With Quote
Old 04-27-2009, 02:48 AM   #17
Using a wallpaper steamer is the only way to go. Just spent over 35 hours stripping wallpaper from the house I bought this month. I still used the paper tiger thing to score the wallpaper to get the steam in better. Using DIF was very slow in comparison. Moving on to texturing and painting now. The previous owner had painted over all 6 rooms of wallpaper and it looked HORRIBLE! Don't do it regardless of any temptation you have. You'll be so much happier to have stripped the paper and painted then wasting your time painting and then want to start over again.
Rebster is offline   Reply With Quote
Old 04-27-2009, 03:59 AM   #18
Learning by Doing
Leah Frances's Avatar
Every time I see a cool wallpaper job, I have to remind myself how hard I've worked to pull all the damn stuff down.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
How many layers of wallpaper is too many? dumbunusedid Painting 14 07-19-2008 05:48 AM
This wallpaper glue is stubborn! proofer Painting 7 03-07-2008 06:53 PM
Removing wallpaper and then painting applesusan Painting 7 02-24-2008 05:32 PM
wallpaper on untreated drywall... rjralston Remodeling 4 09-09-2006 01:13 AM
