Removing Towel Rack To Paint Bathroom - Painting - DIY Chatroom Home Improvement Forum
Old 02-12-2009, 10:53 AM   #1
Removing Towel Rack to paint bathroom
Forgive me if this is the wrong area, but there's the deal:
I'm about to paint my bathroom, taping and removing fixtures. Well, I get to the towel rack and go to unscrew the little screw thing to remove it, and find out that it's not a standard screw. Not a flathead, not a Phillips. It's round, threaded on the outside and hollow on the inside. Shaped like a threaded tube I guess. It's not shaped like it fits an allen wrench, nor is there anything inside that fits a small screwdriver.
Anyone seen anything like this? Any idea how the heck it got put in and how I can remove it?
I may just wind up taping the towel rack and painting around it, but that always looks pretty bad.
Any help appreciated!
thanks,
Nate
Dallas, TX
bigbearok is offline   Reply With Quote
Old 02-12-2009, 03:46 PM   #2
Rewards Points: 2,906
The thought of a STRIPPED Allen head set screw is crossing my mind.
Normally on towel rods, the set screw holding the end bracket to the mounting plate will have a slot or Allen head drive. If it's not a slot, and it's round, it just might be stripped.
Have you tried a 5/64" or 3/32" Allen key in it?
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 02-12-2009, 04:49 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
That's a safety fastener and not meant to be (temporarily) removed
Best to paint around it
slickshift is offline   Reply With Quote
Old 02-12-2009, 05:40 PM   #4
Contractor
cobracdn's Avatar
Go to your local auto parts/tool store and ask them for an small "Easy Out". I the easy out will not go in far enough get your drill out with a bit that easily fits into the end of the screw and drill it deeper, then try the easy out again. http://www.ted-kyte.com/3D/Pictures/Easy%20Out%202.jpg Cheers
cobracdn is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Removing towel rack from tile Cossack Remodeling 6 01-17-2009 08:40 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
