Removing Tape From Woodwork :( - Painting - DIY Chatroom Home Improvement Forum
Old 06-13-2011, 03:51 PM   #1
Removing tape from woodwork :(
Why do I have so much trouble removing painters tape from woodwork?There are always areas that the paint comes off the wall! I may as well forget the tape and cut everything in, I have to go back and touch it all up anyway.
rustyedge is offline   Reply With Quote
Old 06-13-2011, 04:06 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 606
Wrong tape,
improper prep for paint
not enough cure time for paint
any or all of the above
Old 06-13-2011, 04:36 PM   #3
Too Short? Cut it Again!
I try not to use tape unless I have to do so or there are to be many coats. I have been pleased with frog tape. It is supposed to have some patented edge system that seems to keep paint from crawling underneath. I always take a drywall knife and burnish tape down.
Oh well, you will find with a quality trim brush and some practice you will become more confident skipping tape for exactly the reasons you suggest.
By the way, I usually prefer to paint trim first and cut the wall color into it.
Old 06-13-2011, 04:54 PM   #4
General Contractor
Simple fix, if you must use the tape method......be sure to take a razor knife along the tape line before removing it. It cuts the bridge of paint between the wall and the tape for clean removal.
dsconstructs is offline   Reply With Quote
Removing painting tape pks7495 Painting 6 01-04-2011 12:09 AM
painters tape glue on woodwork mbutts54 Carpentry 1 09-01-2010 06:20 PM
Paint problems....or just problems with the painter... deanswife Painting 5 07-30-2010 08:36 AM
Paint pull-up!?!? with BM Aura Bath & Spa, GE Silicone II, and PM Green tape DIYatHome Painting 8 12-12-2009 03:52 AM
removing old drywall tape listo Drywall & Plaster 3 01-15-2009 10:26 AM
