Removing Streaks Caused By Alcohol - Painting - DIY Chatroom Home Improvement Forum
Old 11-05-2008, 12:28 PM   #1
Rewards Points: 852
Removing streaks caused by alcohol
Hi;
My mom is trying to clean up a chest of drawers (Ethan Allen), and at one point used wood alcohol, which left white streaking on the finish.
What is the best way to remove this streaking?
Ultrarunner2017 is offline   Reply With Quote
Old 11-05-2008, 09:20 PM   #2
Rewards Points: 2,906
Clean those white streaks with a damp sponge or rag. See if the white streaks disappear when they're wet and return as the water evaporates. If so, then the white streaks are caused by roughness in the surface of the finish, and that tells me the wood alcohol dissolved the finish. It may have been a shellac finish on that chest of drawers, and shellac is soluble in alcohol.
Nestor_Kelebay is offline   Reply With Quote
Old 11-05-2008, 11:00 PM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
Yep, she disolved the Shellac.
Old 11-06-2008, 05:46 PM   #4
If that's the case, probably the easiest way to fix the problem would be to dip a small piece of rag in some shellac and spread a new coat of shellac over the damaged areas (white streaks). If it wuz me, I'd probably thin that shellac with alcohol just to ensure that it self levelled well after being spread.
Old 11-06-2008, 06:43 PM   #5
Rewards Points: 852
Hey gusy;
Thanks for the advice. She was going to try turpentine, but we'll try the wet rag test and see what happens.
color streaks on new stucco homeowner in Minnesota Building & Construction 2 08-11-2008 08:07 PM
removing treated lumber edging pacifier1er Landscaping & Lawn Care 3 07-02-2008 01:08 PM
removing blown in insulation brownerd HVAC 2 08-09-2006 12:53 PM
removing knockdown texture K_I37 Painting 7 05-07-2006 02:23 PM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 10:28 AM
