-   -   Removing stain and varnish on door frame (http://www.diychatroom.com/f4/removing-stain-varnish-door-frame-28253/)
lorn 08-19-2004 05:38 AM
Hi
I hope I have put this thread in the right place!
I wonder if anyone can help me I have a wood door frame that had been previously stained and varnished and I would like to strip this back to its orginal wood would a normal paint stripper do the job?
Many Thanks for any help
Regards
Lorn:)
lec876 08-26-2004 12:21 PM
Most DIY/harware places will sell varnish stripper solutions. Combination paint/varnish stippers are also common. Alternative a heat gun will strip the varnish but there may be a fume issue depending on the age of the varnish. Also it is quite easy to burn/mark the wood with a heat gun.
This will get rid of the varnish but may not get rid of the stain. Most stains seep into the wood to some degree and are very difficult to remove.
If you want the wood to be darker than it is currently is then no problem simply restain with the new shade. If you want the wood to be lighter you will need to sand the wood once the varnish has been removed.
I suggest you try a small area to see if you can get the desired effect
lorn 08-26-2004 05:59 PM
thank you
Hi Lec876
Many thanks for the helpful advice, thats just what I wanted to know.
Regards
Lorn
