Old 07-31-2010, 07:29 AM   #1
removing rust from a vintage painted cast iron doorstop
Hello, I have a vintage cast iron doorstop that has some rust on it, I want to remove the rust without damaging the paint. Any ideas?
Thank you
Margo is offline   Reply With Quote
Old 07-31-2010, 07:32 AM   #2
Super Moderator
Post a picture if you can---There is no way that I know of. The original paint should be preserved.
Old 07-31-2010, 07:53 AM   #3
http://www.antiqueautoranch.com/mont...rian/rust.html
rustyjames is offline   Reply With Quote
The Following User Says Thank You to rustyjames For This Useful Post:
oh'mike (07-31-2010)
Old 07-31-2010, 02:37 PM   #4
Hi Margo. Check out your local auto-parts store and look for a rust remover/polish made specifically for chrome parts. Because chrome is a really thin plating over metal, it requires a very gentle polish, which should make it safe to use on a painted surface as well (if the correct type of paint was used on the doorstop). Of course, you should test an inconspicuous area first to make sure it doesn't damage the paint. Best of luck!
KennDB is offline   Reply With Quote
Old 03-08-2011, 11:44 AM   #5
That is EXACTLY why I logged in here today! Did you have any luck? I have a couple of Hubley doorstops and love them. One came to me pretty rusty and I want to preserve him as best I can. Thanks for any advice. I don't want to destroy more paint if I can help it.
wisenow502 is offline   Reply With Quote
Old 03-08-2011, 12:41 PM   #6
Super Moderator
Now I'm going to have to google "Hubley doorstop"
Old 03-08-2011, 04:22 PM   #7
Super Master Painter
Ole34's Avatar
i use NAVAL JELLY to remove rust from knives and other things..........you can get it at any automotive or hardware store ...........get a little brush an apply the jell then let it sit for 10 mins then wash it off with cold water an repeat process until you are satisfied..........no sanding required
http://www.epinions.com/review/Naval...t_425434254980
Ole34 is offline   Reply With Quote
Removing a Cast Iron Radiator MugsynSax Plumbing 1 10-05-2009 05:18 PM
Remove Rust from Cast Iron Bed Rails cpalmer67 General Discussion 8 07-24-2009 03:25 PM
working with cast iron ericadami Plumbing 9 11-30-2008 01:45 PM
remove rust cast iron tub workingirl General Discussion 13 08-23-2008 03:41 PM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 09:20 PM
