Old 11-03-2009, 10:53 AM   #16
Heritage Restoration
Up here in Canada there is actually only one company that makes it. It's usually under the name "LPL Mastic Putty" and comes in a 1lb plastic baggy.
I don't know what companies in the USA make it/carry it.
I do know that Viking Sales in the USA carries the Swedish made stuff...
http://www.solventfreepaint.com/window_glazing.htm
...it's really high end stuff. Closer to Restoration/Heritage quality. But it is really excellent to use.
The every-day Putty comes in a little plastic pouch. You can usually see the yellow linseed oil separating in the pouch. Just like the way peanut butter separates. It's not as awesome as the Swedish stuff, but it is easier to get a hold of.
I also recommend the Silent Paint Remover from Viking sales. I bought mine from the Canadian distributor....but it's the same thing.
These paint strippers make Heat Guns look like a base model Honda Civic compared to a Lamborghini. I've never used one that makes stripping paint so easy.
http://www.silentpaintremover.com/
(again...I'm not affiliated with any company...I'm just showing what I have used over the years and what works consistently)
Skuce is offline   Reply With Quote
Old 11-03-2009, 08:08 PM   #17
paper hanger, painter
chrisn's Avatar
Send a message via Yahoo to chrisn
Thanks for the info
Old 11-08-2009, 12:19 AM   #18
No problem!
More On This Topic
Repairing any piece of furniture with wood putty often is an option for do-it-yourselfers. Wood putty is available in different types and a variety of colors. Here's how to make that old piece look new again with this versatile substance. Read More »
Viking Airlines is a new airline based in Stockholm, Sweden. Founded in 2003, the company has quickly grown and expanded its operations to include major hubs in Greece and the United Kingdom. Read More »
Learn materials needed for silkscreening at home and how to screen print a shirt in this free video on silkscreening, or screen printing, clothing. Read More »
There is nothing more annoying than seeing a big white chip in your colored wall. It stands out like a paper cut and looks terrible. Here is an easy way to fix the ding to look like it never happened. Read More »
As much as you may try to keep your palette clean, it's easy to forget occasionally and end up with a palette covered in rock hard dried oil paints. Dried oil paint is never easy to clean, but with some turpentine and a razor blade you can get it back to... Read More »
Double-paned window glass replacement maximizer Building & Construction 5 08-18-2008 02:06 PM
Replacement Windows-Storm Windows simon Remodeling 27 11-17-2007 07:18 PM
Flashing for New Construction Replacement Windows in Stucco House BigJimmy Building & Construction 10 11-03-2007 02:48 PM
Replacing Glass In Windows OVRMYHEAD General Discussion 1 04-26-2007 08:07 PM
Replacement vinyl windows hudson Remodeling 0 03-28-2006 09:49 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
