Removing Peeling Paint From Grooved Cedar Siding - Painting - DIY Chatroom Home Improvement Forum
Old 09-04-2013, 11:37 AM   #1
Removing peeling paint from grooved cedar siding
It's time to repaint and some of my siding is flaking peeling. The siding itself is in fine shape. It's grooved cedar siding.
Obviously sanding is out but how well does pressure washing work for this? I'm thinking a lower pressure so as not to blow out the soft wood, but will that actually remove the paint? Scraping with a wire brush could work as well but that would take a lot of time. Any stripping products worth trying?
The paint peels off nicely when I can catch and edge, but it breaks off where the paint starts to adhere better.
Thanks in advance.
Removing peeling paint from grooved cedar siding-2013-09-04-09.35.55.jpg   Removing peeling paint from grooved cedar siding-2013-09-04-09.36.08.jpg
justinae is offline   Reply With Quote
Old 09-04-2013, 11:51 AM   #2
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,440
How about one of these?
http://www.paintshaver.com/
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is offline   Reply With Quote
Old 09-04-2013, 12:17 PM   #3
Thanks for the suggestion. However, my siding isn't flat.
Old 09-04-2013, 01:16 PM   #4
Jmayspaint's Avatar
Rewards Points: 534
That kind of cedar is tough to strip because of the texture.
If you pressure wash it hard enough to remove the paint, it will fuzz up some.
I recently did some similar cedar shakes that had peeling Sikkens on them. I did a 'medium' pressure washing (2,700psi@ 6-8 inches) then used a wire brush to knock some of the fuzz off.
Only made vertical strokes with the wire brush, to prevent cross grain scratches.
After 3 coats of Sikkens, they looked pretty good.
Jmayspaint is offline   Reply With Quote
The Following User Says Thank You to Jmayspaint For This Useful Post:
Gymschu (09-04-2013)
Old 09-04-2013, 01:18 PM   #5
That's good info. Thanks! Do you have a sense of time it took for say, 100 sq.ft?
Old 09-04-2013, 01:32 PM   #6
Jmayspaint's Avatar
Rewards Points: 534
Well, the gable end pictured is about 250sqft.
I think it took about 12 hr to prep including washing.
Old 09-04-2013, 01:41 PM   #7
That's 20 square feet per hour, not bad.
Was that just you or also a helper at 12 hours?
Old 09-04-2013, 04:16 PM   #8
Rewards Points: 14,010
Siding like this is a perfect example of why not to use paint and use solid stain instead.
Is that siding also really green from mold or is it just the picture?
Sherwin Williams has a solid stain that will go over both the old paint and the bare areas.
Might want to try a hand stainless or bronze wire brush and use it in an up and down motion.
Steel will leave behind tiny flecks that will rust up when coated.
Old 09-04-2013, 04:48 PM   #9
The green is the original primer color.
Good point about the stainless/bronze brush.
I'm getting some quotes to have it pressure washed.
Painting Cedar Siding - Sanding the paint and wood rose ellen Painting 10 03-24-2016 12:37 AM
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 12:10 PM
Vinyl Paint - PolymatrX - and Siding.... Classic Painting 2 07-23-2008 06:45 AM
