-   -   Removing peeling paint from the ceiling (http://www.diychatroom.com/f4/removing-peeling-paint-ceiling-74825/)
Nanna45 06-27-2010 10:40 PM
I scraped the peeling paint from the ceiling but then there was alot not peeling and subsequently is very hard to remove. I have tried to use a paint stripper in a spray can it has helped very little. Any suggestions?
chrisn 06-28-2010 03:24 AM
Originally Posted by Nanna45 (Post 462232)
I scraped the peeling paint from the ceiling but then there was alot not peeling and subsequently is very hard to remove. I have tried to use a paint stripper in a spray can :huh:it has helped very little. Any suggestions?
Why are you trying to remove ALL the paint?? What is it you are looking to do? Paint stripper in a can?
Give us more info to work with.
Nanna45 06-30-2010 12:15 AM
Removing Peeling paint from the ceiling
This is a house that I am renting. The paint has been peeling off the ceiling in a small room. I have scraped the falling pieces and there are 2 layers of paint. Apparently the original ceiling was green and now they tried to go over it with cheap texture paint. I need to remove all of it because there are strips of green old, possibly lead paint, and still some texture paint on the ceiling. If I was to just paint over it now that some of it has been removed it would not look right. But the rest is being pretty difficult to remove. I bought some paint stripper called "Tuff-Strip" in a spray can to apply to the ceiling. It is removing the textured paint some but the green paint is being pretty difficult to remove. I am trying to redo this because my 28 month old granddaughter is now living with me! Any suggestions now on how to get all of the paint off?
chrisn 06-30-2010 03:42 AM
There is no need to remove the original paint. To remove the texture, you should be able to just soak it with hot water from a spray bottle and scrape off. Prime with a good primer( BM Fresh Start, Zinnser's 123) and paint.
