Removing Painted Popcorn Finish - Painting - DIY Chatroom Home Improvement Forum
Old 06-22-2008, 11:56 PM   #1
Bathtub Refinisher
Removing painted popcorn finish
We want to remove the texture off the ceilings. It appears to be painted also.
I tried scrapping it off but that will take forever. I was wondering what other ideas might work.
Mike-the tubguy
tubguy is offline   Reply With Quote
Old 06-23-2008, 01:24 AM   #2
Rewards Points: 2,906
What did you try scraping it with?
If you haven't already, I'd try with one of those Sandvik paint scrapers with the tungsten carbide blade. I find they're sharp enough to scrape real well, but not so sharp as to cut into drywall paper.
Also, by sister removed the texture from her ceiling, but it was presumably softer than yours. She did find, however, that dampening the texture made it easier to scrape off.
Be warned, however. Building contractors don't texture ceilings or use flat paint on walls cuz it's chic or fashionable. They do it because ceiling mounted light fixtures and windows that come within a few inches of a ceiling make it necessary to get that ceiling drywall very smooth or the critical lighting angle of the fixture or window is going to make every imperfection look like a mountain range or the Grand Canyon. When a building contractor wants to avoid any problems which may crop up, the easiest way is to have the ceiling textured instead of painted. That's cuz you can just about hide a dead animal under a coat of texture. You may find some drywall problems or cracked ceiling plaster under there that the texture wuz meant to hide.
Nestor_Kelebay is offline   Reply With Quote
Old 06-23-2008, 05:19 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Generally, once popcorn texture is painted it is very difficult to scrape off. We generally will just "overlay" the ceiling with new 3/8" sheetrock. The amount of labor is essentially, a little less back-breaking, and the result is much nicer and smoother. If you have a vent on the ceiling, or a light, you may have to simply purchase longer face-plate attachment screws.
- Build Well -
Old 06-23-2008, 05:43 AM   #4
Example of overlying with new 3/8" sheetrock:
Poorly textured ceiling (hard texture):
Overlayed with 3/8" sheetrock:
Last: Attic Door overlayed with 1/4" sanded plywood (much easier than trying to scrape this very hard texture off):
When done, door was primer-sealed and all (door and ceiling) was painted flat white ceiling paint. All in all, much, much easier than attempting to scrape it all off.
- Build Well -
Old 06-23-2008, 10:11 PM   #5
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 876
Get a Garden pump sprayer. Wet a 3'x5' section. Let it sit for 5 minutes. Scrape w/ a 6" or 8" taping knife. Repeat if necessary. (because it was previously painted) Then move on to next 3'x5' section.
These pictures are from a popcorn removal job we did. Then we sprayed a Knockdown texture, primed, and painted it.
Removing painted popcorn finish-1.1popcorn.jpg   Removing painted popcorn finish-img0201me5.jpg   Removing painted popcorn finish-img0203uc7.jpg   Removing painted popcorn finish-img0208ub6.jpg
Sir MixAlot is offline   Reply With Quote
Removing Polyurethane Overspray for cars paint finish... Norm Automotive Repairs 5 05-25-2014 08:58 PM
Removing textured finish from kitchen cabinets jbwaechter Remodeling 6 10-04-2010 02:12 PM
Removing painted popcorn texture from ceiling cnielsen4130 Remodeling 8 10-08-2007 12:21 AM
Retexturing painted popcorn ceiling kwehnes Building & Construction 6 01-02-2007 05:36 AM
Removing popcorn from ceiling? Doug Crf Painting 5 05-22-2006 09:23 AM
