Removing Painted Grasscloth Wallpaper - Painting - DIY Chatroom Home Improvement Forum
Old 07-14-2012, 06:16 AM   #1
Removing painted grasscloth wallpaper
This is in 4 rooms of my house so I am looking for an easier way. I have tried scoring with the Paper Tiger and using a steamer but I am just not getting enough penetration and getting a couple square feet an hour isn't going to work. I could dry peel away the top layer but that is also quite labor intensive (the bottom layer comes away easily when moistened).
Any hints would be appreciated.
mikeatuconn is offline   Reply With Quote
Old 07-14-2012, 07:27 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
This is going to be a mess if it is true grasscloth. The tiger, as you found out, is worthless for this. I'm surprised that the steamer didn't work-
here's something to try-
get the roughest sandpaper you can- i like to get the coated 36 grit belt sander belt- i will cut it to put on a hand sander- then go to town and rip up that paint.
use a garden sprayer ( paint stores sell a small pump sprayer sometimes in the wc dept that work good) and wet it real good. Let soak and rewet until it is really giving. Work in sections wetting ahead of where you are working- it is always about timing and patience.
use a variety of mudding knives to see which gets under it the best- often for me it will be a 4" flex.
good luck!
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 07-14-2012, 09:44 AM   #3
ltd
Rewards Points: 536
yep that's right ,a garden sprayer is a must .my old one gave out after many years. just had to buy a new one .i got it a lowes in garden dept. its an ortho and sells for about 15 bucks.dragging a saw over it , scraper anything you can do to allow water to penetrate with out damaging the wall .you have to think out of the box on this one ,they left this chapter out ,but its very do able.
ltd is offline   Reply With Quote
Old 07-14-2012, 05:32 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 312
After doing what brush said with the sand paper
SOAK SOAK SOAK and SOAK
Grass is usually one of the easiest materials to remove because it holds the removal solution well. BTW this is the best solution out there
http://www.safeandsimple.com/
Old 07-20-2012, 06:11 AM   #5
I'm really considering just re-drywalling at this point.
Old 07-20-2012, 10:56 AM   #6
ltd
Rewards Points: 536
if your thinking about re sheet rocking dont .i laugh to myself how people think ,oh yea ill tear it down and re rock. its not easy. you have baseboards window trim electric outlets door casing hanging taping mudding mudding again dust everywhere . its a job for a diyer . but yea it can be done . ok you had it ,i get that .of course with out seeing what your up against and i cant say for sure but i think all of the painters and paperhangers on this site could strip it no problem.get some estimates it might actually save you money in the long run
The Following User Says Thank You to ltd For This Useful Post:
chrisn (07-20-2012)
Old 07-20-2012, 02:37 PM   #7
nice information dude...
www.myhomedesign.net
kaka09 is offline   Reply With Quote
Removing painted popcorn texture from ceiling Norva Drywall & Plaster 5 02-02-2010 11:24 AM
Painting after removing Wallpaper fozzie Painting 4 11-03-2009 05:59 PM
Removing Wallpaper Paste Bliss7777 Painting 13 08-07-2009 04:46 AM
Removing wallpaper and then painting applesusan Painting 7 02-24-2008 04:32 PM
wallpaper on untreated drywall... rjralston Remodeling 4 09-09-2006 12:13 AM
