Removing Paint From Wood Wall Panels - Painting - DIY Chatroom Home Improvement Forum
Old 08-02-2010, 08:31 AM   #1
Removing Paint from wood wall panels
In my dining room, there are walls that are wood panels that have been painted over. Id like to remove them to expose the wood. For the most part, the paint comes off rather easily, except for the crevices where the wood meets each other as seen in the pic. Any tips on how to remove the paint efficiently with out damaging to wood too much?
Molson is offline   Reply With Quote
Old 08-03-2010, 12:22 AM   #2
Rewards Points: 526
I would peel as much off as I possibly could with flat drywall knives and then gently use a heat gun and specialty angle scrapers (available at woodworking stores) to get the paint in the crevasses and corners and anything else still stuck down.
Windows is offline   Reply With Quote
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 08:38 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 11:18 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
