Removing Paint From Varnished Trim - Painting - DIY Chatroom Home Improvement Forum
Old 12-31-2012, 10:25 AM   #1
Rewards Points: 156
Removing paint from varnished trim
My wife and I moved in an new home about a year ago. The previous owner in an attempt to sell the house, painted everything in the house with white latex paint. The trim around doors and windows was previously varnished or polyurethaned prior to this reckless paint job. The paint is now starting to chip off whenever it is bumped, and already beginning to look terrible. The exposed woodwork in the other homes in the neighborhood looks great
What would be the easisest way to remove this paint and expose the nice wood again. What type of stripper would remove the glossy latex paint, but not damage the oil based varnish underneath? I am willing to do a little sanding and poly afterwards, but don't want too messy of a job.
av-geek is offline   Reply With Quote
Old 12-31-2012, 10:38 AM   #2
Rewards Points: 13,300
Not going to happen, anything strong enough to remove the paint will also remove the poly.
The fastest least messy way would be to remove the trim and replace with new stain grade trim that's been prestained so your not getting the stain all over the walls.
Old 12-31-2012, 11:06 AM   #3
DIY staff
Rewards Points: 7,174
Joe's right---stripping trim in place will be a mess---and spoil the paint on the walls around the woodwork----
If the trim is really unusual and not easy to duplicate--stripping will be an option---but the cost of stripping (if your time is work anything) will be as much or more than replacing it----
New Roof but Fascia Trim Board Rotting ein0801 Roofing/Siding 6 07-15-2012 01:21 AM
How do I paint Cabinet Trim to Match Stained Doors? Mjakester Painting 2 03-31-2012 07:09 AM
Removing Paint from old trim josephr33 Painting 3 06-29-2010 03:29 AM
Sheetrock put on w/o removing door trim Carla33 Carpentry 13 12-26-2009 02:32 AM
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 08:45 AM
