Removing Paint Smell - Painting - DIY Chatroom Home Improvement Forum
Old 09-14-2010, 09:26 PM   #1
Removing paint smell
hello.
I have a used safe I bought.
I decided to repaint it, so I bought some of the old reliable, Rustoleum. I used the primer, and finished it with flat black. It's been three weeks so far, and the smell is still very strong. I don't think this would be good for my documents and antique watches I plan on storing in it.
I called Rustoleum, and the suggestion I got was "wash it with mild soap and water", which I have done repeatedly, but with no reduction of the fumes. Any suggestions? I am not sure that the Rustoleum helpline is helpful!
Regards,
Gene
Tesla is offline   Reply With Quote
Old 09-15-2010, 10:17 AM   #2
Hi Gene.
In time this will get better, there really is not no real quick fix with this. The paint you used is probably oil based and that takes 30 days or longer to fully cure. Heat,Humidity/etc are factors. IMO take a fan and use it on the safe as so you get a good amount of fresh air circulating. But like I said, time is what it will take.............
mark942 is offline   Reply With Quote
Old 09-15-2010, 11:11 AM   #3
Rewards Points: 558
You can use white vinegar to get rid of the remaining odor by setting a small bowl of white vinegar in your safe. Add a little fresh vinegar every day for 3 days and this should take care of the smell. If that doesn’t work then use charcoal briquettes or pieces of plain wood charcoal. Fill a brown paper bag with 2 to 4 cups of charcoal and set the bag in your safe. Charcoal absorbs many odors and is most frequently used to prevent musty odors in turned-off refrigerators, but it works well with removing paint odors, too. Leave charcoal in place as long as you need it, which is usually only a few days or less.
epson is offline   Reply With Quote
Old 09-15-2010, 06:31 PM   #4
Originally Posted by Tesla View Post
hello.
Regards,
Gene
Thanks guys, I will try both of those suggestions!
Gene
removing paint from interior brick? suzan30 Remodeling 4 01-05-2010 05:05 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
removing paint mpj111 Painting 2 12-15-2008 04:00 PM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
