Removing Paint From Painted Trim - Painting - DIY Chatroom Home Improvement Forum
Old 04-03-2013, 07:34 PM   #1
elizabrat72's Avatar
Removing paint from painted trim
HELP! My fiancÚ and I are reprinting our home which is 100 years old. The trim has been painted (at least once), and I would love to know what is the best way to remove the paint from the trim without removing the trim from the window frames etc....
elizabrat72 is offline   Reply With Quote
Old 04-03-2013, 07:38 PM   #2
Gymschu's Avatar
Rewards Points: 934
Well, before you even think about stripping any paint, make sure you test for lead. Most big box stores have lead kits for about $30.
The Following 2 Users Say Thank You to Gymschu For This Useful Post:
r0ckstarr (04-08-2013), user1007 (04-04-2013)
Old 04-03-2013, 08:10 PM   #3
cdaniels's Avatar
Why strip it?You might be opening a can of worms better left closed.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 04-03-2013, 08:11 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
Stripping is a huge undertaking in the best circumstance. I would also say fix it up for a nice paint job.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 04-04-2013, 03:45 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 498
100 year old house = lead paint for sure.
I would leave it alone( as in paint over it)
Why stripping????
The Following User Says Thank You to chrisn For This Useful Post:
cdaniels (04-04-2013)
Old 04-04-2013, 08:32 AM   #6
The trim looks terrible, so is this a case where we should just paint over it?
Old 04-04-2013, 08:35 AM   #7
Rewards Points: 14,014
Post a picture.
If it's 100 years olld you can be sure of two things, it's been painted way more then once, and there's going to be lead based paint.
If there's nothing special about the profile and what you have is really that bad then replacing it with new wood may be an option.
Old 04-04-2013, 02:58 PM   #8
Gymschu's Avatar
Rewards Points: 934
One common misconception about stripping wood is that you will end up with beautiful looking trim after all the work. The fact is, there was a reason it was painted over and that reason is that it was looking like crap. I vote for painting over it.
Old 04-04-2013, 05:27 PM   #9
Matthewt1970's Avatar
Rewards Points: 1,098
I bet you could replace the trim easier than stripping it.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
Gymschu (04-04-2013)
Old 04-05-2013, 07:30 AM   #10
Rewards Points: 5,988
I gotta say if this is the original trim I would try to save it. Back then a lot of quality wood was used for trim, not the crap we get today. And as far as lead, it may have only been painted 5 years ago so test it. What I might suggest is get some peel bond try it in an inconspicuous spot, see if the trim is a wood worth saving. Then decide wether to paint or replace. A lot of those old homes had walnut and mahogany trim. But over the years some people got tired of them and painted them.
ToolSeeker is online now   Reply With Quote
The Following User Says Thank You to ToolSeeker For This Useful Post:
MSR (04-05-2013)
Old 04-05-2013, 08:43 AM   #11
Got a picture of this trim so we can see just how bad, bad is?
Old 04-08-2013, 06:45 PM   #12
Pics to follow....
Removing paint from painted trim-image-3115503920.jpg   Removing paint from painted trim-image-4081781944.jpg   Removing paint from painted trim-image-388112601.jpg   Removing paint from painted trim-image-4146148195.jpg
Old 04-08-2013, 07:08 PM   #13
From what little I can see in pic #3 it looks like it could be good wood.
Old 04-08-2013, 07:09 PM   #14
Also looks like it could be striped with duct tape..
( press, pull)
Old 04-08-2013, 07:43 PM   #15
Okay, so what's the best way to strip it? We have no idea if it's lead paint or not, and it's our understanding that if we test for lead paint, it gets reported, and that's not something we want at this point. Too much expense to have it taken care of. Our children are all over 6, so eating paint chips isn't an issue for us
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Removing paint from varnished trim av-geek Painting 2 12-31-2012 10:06 AM
Bathroom and Trim Paint tev9999 Painting 3 12-07-2012 08:28 PM
Removing paint from a old painted doorstop twelvecats2 Painting 1 08-09-2011 11:32 AM
Removing Paint from old trim josephr33 Painting 3 06-29-2010 02:29 AM
