Removing Paint From Outside Door Weather Strip - Painting - DIY Chatroom Home Improvement Forum
Old 09-08-2013, 09:18 AM   #1
Rewards Points: 388
Removing paint from outside door weather strip
Is there any way to remove this paint? The old owner did a sloppy paint job and I'd like to fix it.
It looks like the strip is embedded in the door frame otherwise I'd just replace it.
Removing paint from outside door weather strip-image-1633695306.jpg   Removing paint from outside door weather strip-image-2773980723.jpg
Central New Jersey Area
adgjqetuo is offline   Reply With Quote
Old 09-08-2013, 09:48 AM   #2
Jmayspaint's Avatar
Rewards Points: 534
You should be able to remove the weather strips. They look embedded in the door as you say, and they are but they are generally made to come out. On rare occasions I've seen them glued or nailed in, even then they will usually come out ok if your planning on putting new back.
Use a putty knife or 5in1 to get it started, then just pull it out. The new should go right back into place.
If indeed you have a different kind of strip that cannot be removed ( not likely on any fairly new door) denatured alcohol will take some of the paint off if its latex. They don't clean up too good though, that's why painters take them out. That, an so the door can close when it has wet paint on it.
Removing paint from outside door weather strip-image-1293680439.jpg   Removing paint from outside door weather strip-image-3071248071.jpg   Removing paint from outside door weather strip-image-3423225124.jpg   Removing paint from outside door weather strip-image-1077037871.jpg
Jmayspaint is offline   Reply With Quote
Old 09-08-2013, 09:57 AM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
Yep, those should come out.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 09-08-2013, 10:38 AM   #4
cdaniels's Avatar
Definitely replace them.The work it would take to remove it even if you could far outweighs the cost of new stripping.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 09-08-2013, 12:16 PM   #5
Rewards Points: 388
Ok so I pulled hard and it is removable - do you need a special tool to get it back in? I tried a putty knife and it wouldn't budge back in the groove, almost wants to puncture it instead
Old 09-08-2013, 01:38 PM   #6
Jmayspaint's Avatar
Rewards Points: 534
No special tool. In theory they just pop back in by pushing with your fingers.. But they can be a pain to get started.
Old 09-09-2013, 05:16 PM   #7
Rewards Points: 256
Whenever I finish a door I almost always replace the weather strips. You can buy them at either Lowes or HD. They’re around $5/$6 a strip. You’ll have to trim them to length. When you do, start trimming them longer than you need, then cut off a little at a time. My mistake the first time was I cut what I thought was enough but was too much. Don’t make the same mistake.
Best of Luck
Steve
spraygunn is offline   Reply With Quote
Old 09-09-2013, 08:59 PM   #8
Roofmaster
Rewards Points: 2,172
One of my Aunt Marge's favorite sayings "I cut it twice and its still too short"
Coat the tongue with bar soap and it should go in pretty easily by tapping with a block of wood.
Removing paint from varnished trim av-geek Painting 2 12-31-2012 11:06 AM
Removing Paint nevilshute Painting 6 07-04-2011 01:31 AM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
