Removing Paint From Drywall - Painting - DIY Chatroom Home Improvement Forum
Old 06-29-2010, 04:12 PM   #1
Removing Paint from Drywall
I just bought a fixer-up condo and we noticed that the paint is separating from the walls in a couple of rooms. It also appears that they may have painted over wallpaper at some point.
Any suggestions on how to get this mixture off the walls?
Hellback is offline   Reply With Quote
Old 06-29-2010, 09:28 PM   #2
There's only two things worse then stripping wallpaper and one is stripping wallpaper that's not been sized and the other is stripping painted over wallpaper.
Use a wallpaper perforator and then spray a hot mix of water/vinegar and let it soak thru the peforations and loosen the wallpaper.
Pull as much off as you can. Use a plastic putty knife to encourage the stubborn spots.
Repeat as necessary. This will be a miserable task - good luck. I hate wallpaper!!!
hennyh is offline   Reply With Quote
Old 06-29-2010, 09:47 PM   #3
My last house I used a hammer
Drywall was a terrible job...complete redo
Old 06-29-2010, 10:08 PM   #4
Rewards Points: 526
I wouldn't try to remove painted on wall paper. Either replace the drywall or use oil to seal the papered walls and drywall mud to skim them. Peeling the paper is probably a lost cause.
Windows is offline   Reply With Quote
Old 07-01-2010, 10:03 AM   #5
I think I will try to remove the paint/paper first as I can do this myself. If not I will have to resort to replacing the drywall. Hopefully I won't have to go this route as it will require permits and hiring a drywall hanger and finisher.
Old 07-01-2010, 09:47 PM   #6
permits are needed to hang drywall in your area? really? i wonder what the exact wording is. at any rate, i have a wall just like you described. i also tore it out, replaced the drywall and had it mudded and taped in less time than i ever would have spent trying to save that old stuff.
racebum is offline   Reply With Quote
Old 07-02-2010, 03:31 AM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
really??
chrisn is online now   Reply With Quote
Old 07-02-2010, 09:11 AM   #8
It is my understanding after talking with the City that removing a substantial amount of drywall is considered "Renovations" and requires a permit to insure it is being done correctly. I think they just want their $50.00.
This City has very strict building codes, you have to have a Licensed Plumber to replace a hot water tank. If they see the box in the gargbage, they will actually check to see if you got a Permit, and make you give the name of the plumber who installed it so they can verify their credientials.
Old 07-02-2010, 10:35 AM   #9
One reason I burn every box !!!
I've never heard of drywall needing a permit
Maybe they figure people will be doing more then drywall once the drywall is off
Old 07-02-2010, 02:29 PM   #10
substantial is subjective. if you're only doing one wall is there any risk in just going for it? if the city says anything all your work will be done properly. i really hate it when they use words like that. it really gives you no clear idea of what can and can not be done.
http://www.amazon.com/Drywall-Hangin...8098670&sr=8-1
is a video that is extremely helpful if you're new to drywall.
usg also has a free packet you can download in a pdf on their site.
removing oil based paint off of brick handycanuck Painting 1 06-18-2010 12:14 PM
Removing built in drywall shelves to wall mount TV homerb Project Showcase 0 05-19-2010 12:34 PM
removing paint goldrunner_7 Painting 1 07-07-2009 08:17 PM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 10:18 AM
Removing Old Drywall Fearless Freep Drywall & Plaster 5 10-03-2008 07:48 AM
