Removing Paint Drips Off Baseboard? - Painting - DIY Chatroom Home Improvement Forum
Old 01-15-2008, 09:37 PM   #1
removing paint drips off baseboard?
Hi everyone-
I painted the other day and got some of the flat on my baseboards- how do I safely remove the brown colored paint off the semi glosss covered baseboard? I was thinking of lightly sanding it down, but I am afraid that i wont get through the mils that are on there, and it will look ridiculous.
Any suggestions from the pros?
Thanks a ton guys
silva12 is offline   Reply With Quote
Old 01-16-2008, 12:27 PM   #2
Workaholic's Avatar
Rewards Points: 268
Are you going to paint the base? If so you could sand or scrape off your drip and paint base.
If you had no plan to paint base you can probably pull it off with some oops or goof off. oops would be my pick. Since it is fresh it should come off pretty easy.
Next time carry a wet rag with you and keep an eye out for drips or splatters, and get them cleaned off right away.
Sean
Workaholic is offline   Reply With Quote
Old 01-16-2008, 07:19 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
Fingernail
Putty knife
Oops!/Good Off!
No sanding, that would be bad
slickshift is offline   Reply With Quote
Removing paint from hardware ciera Painting 11 09-10-2007 09:03 PM
Removing spray paint from tools harold938 General DIY Discussions 15 12-17-2006 07:16 AM
Removing Paint from Bricks ? Piney Painting 7 11-16-2006 01:17 AM
Removing paint from hardwoods amclaugh Flooring 4 09-17-2005 08:49 AM
What paint for baseboard registers? Unregistered Painting 1 02-05-2004 08:17 AM
