Removing Paint Chemically - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-08-2009, 11:16 PM   #16
Send a message via AIM to rh8868 Send a message via MSN to rh8868
Peel Away
Just wanted to thank Amakarevic for suggesting this product. I have a fireplace that had been covered with multiple layers of paint, then black glass panels put over top of that. I decided to try the Peel Away product because of your photos and it worked very well. I still need to do the sides and repair some brick behind the mantel, but it is looking pretty good. I think I'll try and clean up the mortar a little more with a wire brush or riffler rasp and then apply a small amount of mortar for looks, because the bricks came so clean they look nearly new. I was so relieved the bricks werent the standard red, I think they go better with the wood floors. Thanks again!
removing paint chemically-living1.jpg   removing paint chemically-living2.jpg   removing paint chemically-fireplace1.jpg   removing paint chemically-fireplace2.jpg   removing paint chemically-fireplace3.jpg
rh8868 is offline   Reply With Quote
Old 02-09-2009, 10:07 AM   #17
Rewards Points: 1,062
you are very welcome. glad it all worked out for you. there were innumerable "experts" on this forum who said that an elaborate sand blasting job was the only way to go about it and yaddi-yaddi-yadda ... chemical is really the best way to go. i cannot tell there was ever paint on my bricks.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
