Removing Paint Chemically - Painting - DIY Chatroom Home Improvement Forum
Old 12-29-2008, 01:47 PM   #1
Rewards Points: 1,062
removing paint chemically
i have an indoor brick wall, actually, a couple, that i would like to strip old (lead-based) paint from and restore it and have it exposed. i was told the only way to do it was pressure washing but that can be messy.
an idea just occurred to me why not try to do it chemically with some sort of a thinner that can be applied on the bricks and then wiped off with the paint dissolved in it ? am i onto something or way off ?
thx,
- a -
Old 12-29-2008, 02:10 PM   #2
this is something i just found:
http://www.dumondchemicals.com/html/peelaway.htm
Old 12-30-2008, 05:18 AM   #3
Rewards Points: 506
If you want to remove lead-based paint, especially indoors, your one and only option is to contact your local health department and ask them what the acceptable ways of removing lead-based paint are. If you remove the paint improperly, it will become a big problem when it is time to sell, and you have to sign the legally-required lead-paint disclosure form.
All that said, removing paint from brick completely is extremely difficult. I would imagine it would take a very large number of stripper applications to dissolve the stuff.
SirWired
sirwired is offline   Reply With Quote
Old 12-30-2008, 11:38 AM   #4
Question
SirWired
thanks for your advice but i am not going to my city bureaucratzillas for this. the wall i am restoring was under some ugly wood panels before and there is no way for them to know whether it was painted or not. if they were less bureaucratic, i would be more friendly about keeping them in the loop.
i talked to the guy from the company that makes Peel Away and he said this product would do it but, of course, he is not impartial. are you saying it is hard to strip paint from bricks in general or specific to this product?
you know, everyone is saying it is hard but i keep seeing restored exposed brick walls all over town so I KNOW there are ways to do it immaculately. there just have to be.
Old 12-30-2008, 04:53 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
Originally Posted by amakarevic
....i keep seeing restored exposed brick walls all over town so I KNOW there are ways to do it immaculately. there just have to be.
There is
Media/Water blasting (a combo of both)
It's not a DIY friendly process, and should be hired out
You might...and I mean might...have a reasonable amount (percentage) of success using chemicals
Even if you did, it would be very time consuming and very messy...very
I would by no means suggest it
slickshift is offline   Reply With Quote
Old 12-30-2008, 04:57 PM   #6
i already bought Peel Away. does not have to be immaculate - a little paint left here and there could have its charms ... i will tuckpoint the mortar in between and then glaze the bricks, it will look super
Old 12-30-2008, 05:15 PM   #7
slickshift's Avatar
Good luck!
Please post back how it works out!
Old 12-31-2008, 02:36 PM   #8
Rewards Points: 506
Your problem isn't necessarily going to be with the city. The problem will arise when it comes time to sell your house, and you are presented with the HUD-mandated Lead Disclosure Form. In it you must disclose any known lead-based paint hazards. Lead paint removed without the legally-required remediation is likely considered a hazard. A buyer may not like that very much. Fibbing on the form opens you up to a large lawsuit if the problem is found down the road, and that suit would probably not be covered by your liability insurance.
SirWired
Old 01-01-2009, 10:03 PM   #9
peel-away ROCKS !!!
i made two separate test patches and here is what the cleaned areas look like. it looked just like what surrounds it, maybe even worse, i tried to pick the toughest spots for testing.
removing paint chemically-peelaway_1_prcsd.jpg   removing paint chemically-peelaway_2_prcsd.jpg   removing paint chemically-peelaway_3_prcsd.jpg   removing paint chemically-peelaway_4_prcsd.jpg
Old 01-01-2009, 10:40 PM   #10
Originally Posted by slickshift View Post
There is
percentage of success = 100. dude, seriously - PEEL AWAY 1 for oil-based paints. MIRACLE !!
Old 01-02-2009, 05:05 PM   #11
slickshift's Avatar
That is very impressive
Thanks for the update!
Old 01-02-2009, 05:10 PM   #12
it was unbelievably easy to do. the only thing it is a little expensive - a 5 gal bucket is about $160. 1 gal does about 15 sq ft. my whole project will cost about $350, which i will gladly pay, considering the effectiveness and cleanliness.
Old 01-04-2009, 02:39 PM   #13
Hi, I've been trying to do the same thing for a while in my basement only I am in Toronto Canada and I can't seem to find this product anywhere. Do you have any idea where to get it?
Harry
potatodog is offline   Reply With Quote
Old 01-04-2009, 04:11 PM   #14
slickshift's Avatar
Though you should be able to get it from a Sherwin Williams dealer, I don't know if they are Canada
Try your local Benjamin Moore dealers
They are independent dealers (not paint company owned), so they may carry, or be able to get the product
You will not find it at Big Box Home Centers
Old 01-05-2009, 08:41 AM   #15
Sherwin Williams
Yes. They have it.. just spoke to a guy... you were right about the price though... its about 40 CDN per gallon but it looks like it's worth it.
Just an idea... the active ingrediant is lye (caustic soda). I found a recipie for lye based stripper which uses lye, water and a thickening agent for vertical surfaces (corn starch). I may look at trying to make it myself once I see how the paper system works.... you can by lye (or make it from ash if you have a fireplace... ) for a couple bucks a gallon....
Cheers
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
