#1 |
Removing Paint from Bricks ?
Greetings---
Previous sloppy painter left white paint brush marks and drips on the brick. What is the best way to remove this excess paint and still keep the bricks looking OK ? None of it came off when I power washed the wood portions of the house.
#2 |
Pro Painter
The easy way would be to get the painter back there to take it off.
How old is the paint? Is it latex? Is there a lot of it? You could try goof off and a wire brush or just plain water and a wire brush. Try to get the paint wet and keep it wet for at least a few minutes before removal. Maybe even give it a scrape first and then wet it. At least that's a start. Last edited by joewho; 11-15-2006 at 04:19 PM. |
#3 |
pressure washng the brick should work, unlike the wood where it will sloak into it, putting about 1600 psi or more should remove the paint from the brick. But be aware, you might have to do the intire wall if it not very clean. you don't want to have a section that looks newer than the rest. Also be careful around the mortar, you do not want to wash it out as you will have a hard time matching with new mortar.
#4 |
Tired, Cold, and Damp
Oil or latex?
Latex, I'd do the Oops!, or Goof Off, and wire brush thing Oil...try brick remover |
#5 |
World famous jerk.
Removing Paint from Bricks ? |
#6 |
Careful of using too much pressure when P-Washing brick. You can make the problem worse by causing efflorescence..thats that pretty white scaley stuff that looks like scum or crystals on brick face.
#7 |
made in U.S.A.
I had overspray on my own chimney from previous painters. Tried the wire brush trick with water and soap, and with paint thinner.
Forget it....nothing budged, and I was looking at two stories of bricks. So I took a leftover brick to the paint store and got an "eye match", then ordered a gallon of premium exterior flat latex. I then weenie rolled every brick with a dry roller, 1/4" nap, being careful around each mortor joint. Now don't start laughing, it wasn't that bad of a job and didn't take as nearly as long as I thought; my chimney looks great!
People sleep peacefully at night because rough men stand guard to deal with violence on their behalf. |
#8 |
Pro Painter
I thought you were going to say you rubbed a brick on the painted brick
If the paint isn't very old, goof off should work. If older you can move on to stronger and stronger chemicals from laquer thinner to methylethylketone (MEK) Last edited by joewho; 11-16-2006 at 06:56 PM. |
| Display Modes | |
| Removing paint from hardware | ciera | Painting | 11 | 09-10-2007 10:03 PM |
| Removing paint from aluminium | victor | Painting | 4 | 08-14-2007 10:55 AM |
| Removing paint from finished wood | 9c1 | Painting | 1 | 05-20-2007 07:14 PM |
| Removing spray paint from tools | harold938 | General Discussion | 15 | 12-17-2006 08:16 AM |
| Removing paint from hardwoods | amclaugh | Flooring | 4 | 09-17-2005 09:49 AM |
