Removing Paint From Baseboards W/out Ruining Them - Painting - DIY Chatroom Home Improvement Forum
Old 07-20-2008, 04:36 PM   #1
New to DIY projects
Removing paint from baseboards w/out ruining them
I painted my town home 7 years ago when I wasn't at all "painting savvy" and throughout my house there is dried paint on baseboards, window frames, etc. I'm now going to repaint the "proper" way, most likely hiring a professional. How do get all the dried up paint off the baseboards w/out ruining the wood?
angelar is offline   Reply With Quote
Old 07-20-2008, 10:18 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
If the trim was painted, scrape off as much as possible with a putty knife, then sand smooth
If the trim was stained and poly'd, and is going to be painted, then the procedure is te same
If the trim was stained and poly'd, and will remain so, then you could try the putty knife, and maybe some Goof Off! or Oops!
But confidence is not high for that working well
If the trim was stained, and will remain that way, replace the trim
slickshift is offline   Reply With Quote
Old 07-21-2008, 12:37 AM   #3
Rewards Points: 2,756
Was the paint you dripped onto your baseboards a latex or oil based paint?
Was the coating that was already on the baseboards a latex or oil based coating?
I regularily use xylene to remove latex paints from oil based painted surfaces. There is no reason why it wouldn't also remove latex paints from a varnished or polyurethaned surface.
If the xylene dulls the gloss of a varnished surface, you could fix that by simply applying some "Wipe on Polyurethane" (the kind furniture makers use for their final coats) to a soft tissue and wiping that over the dulled area.
Nestor_Kelebay is offline   Reply With Quote
Tags
baseboards , paint , painting
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
remove caulking/chunky paint from baseboards stallinc Painting 3 01-31-2008 10:27 AM
Removing spray paint from tools harold938 General DIY Discussions 15 12-17-2006 08:16 AM
