Removing Paint From Aluminium - Painting - DIY Chatroom Home Improvement Forum
Old 08-13-2007, 12:39 PM   #1
Removing paint from aluminium
hello
Why can't i remove paint from aluminium with paintstripper?
At the DIY store they could't give me an answer, only that i will get burnmarks.
Because it's 6m2 sanding is not realy an option, burning it of neither beacause ther is polystirene behind it.
Thanks for taking the time to reply.
victor
victor is offline   Reply With Quote
Old 08-13-2007, 03:33 PM   #2
fierysun's Avatar
Sorry I don't your answer, but I've used "aircraft stripper" found at an automotive store to remove paint on some trim pieces. This did not come out favorably. The paint came off with a little work, but the aluminum reacted with the stripper turning it a dull gray and sometimes blackish in color. I had to use steel wool to remove the discoloration. More work doing it that way than if I had just sanded the pieces.
Trying to keep all my fingers and toes
Personal site
fierysun is offline   Reply With Quote
Old 08-13-2007, 08:04 PM   #3
Guest
Guest
Posts: n/a
from everything I've read on it, which is admittedly little, there is no easy way to do it yourself. The aircraft strippers are about the best you can get as a DIY customer. There is a product from a company called Miles I've read something about in the past that touts itself as a low temp stripper that is safe on aluminum. There were no details about what they mean by "safe" and I've seen no reports on how well it works.
Old 08-13-2007, 09:48 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
I can't answer why, only add my voice to the "don't know hows"
No good way, anyway
slickshift is offline   Reply With Quote
Old 08-14-2007, 10:55 AM   #5
fierysun's Avatar
I have removed the black paint and yellow primer from a set of aluminum boat window frames, using a methylene chloride-based paint stripper (sold in Canada as LePage Poly Super Strippa) and 3M stripping pads.
http://www.finishing.com/383/22.shtml
The guy above used the equivalent of aircraft stripper and still had to do manual work with the stripping pads to get all of the paint off.
According to this pdf you need to be careful when using alkaline or acidic strippers on aluminum because there is possible metal degradation.
Hope this help a little
Personal site
Removing paint from hardware ciera Painting 11 09-10-2007 10:03 PM
Removing paint from finished wood 9c1 Painting 1 05-20-2007 07:14 PM
Removing spray paint from tools harold938 General DIY Discussions 15 12-17-2006 08:16 AM
Removing Paint from Bricks ? Piney Painting 7 11-16-2006 02:17 AM
Removing paint from hardwoods amclaugh Flooring 4 09-17-2005 09:49 AM
