Removing Paint - Painting - DIY Chatroom Home Improvement Forum
Old 10-08-2008, 12:52 PM   #1
HCC Engineering
removing paint
What types of solvents can I use to remove splattered paint thats on concrete.
HCC engineering is offline   Reply With Quote
Old 10-08-2008, 01:33 PM   #2
RippySkippy's Avatar
Anything that will work?
Just kidding...do you have any idea what kind of paint your working with? Is the concrete smooth, rough? What have you tried? I would suggest trying a heat gun...if you can loosen the paint a bit and scrape it up you'll be better off than trying to dissolve it an spread it further, just a thought.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
oil base paints NoExperience Painting 30 09-04-2008 06:37 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
