Old 11-06-2011, 09:11 AM   #1
removing paint
howw do i remove ind. red spray paint off concrete.,outside a storage shed.
harebear is offline   Reply With Quote
Old 11-06-2011, 10:13 AM   #2
jschaben
removing paint
Problem isn't so much getting the paint off concrete, it's getting it OUT of concrete. Concrete is very porous. If it is pretty well cured, I would probably use a angle grinder with a knotted wire cup brush. Will likely leave some marks in the concrete though.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 11-07-2011, 06:00 PM   #3
removing paint
hydrochloric acid, 30% or more should do it
the_wanderer is offline   Reply With Quote
Old 11-07-2011, 06:09 PM   #4
jschaben
removing paint
I bet it would
Muriatic acid is a 30% concentrate and that's normally cut 10:1 for etching.
John Schaben
Removing paint from cement TheDodoBird Painting 1 09-14-2011 02:59 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
removing oil paint from interior cement wall shrinkinfoot Painting 0 08-31-2011 07:10 PM
Damaged paint when removing tape somuchjackson Painting 11 08-10-2011 08:07 AM
Removing paint from utility trailer pomelo Painting 1 02-26-2010 10:38 AM
