Removing Over-paint From Interior Wood Trim - Painting - DIY Chatroom Home Improvement Forum
Old 08-13-2007, 11:14 AM   #1
sestivers's Avatar
Rewards Points: 101
Removing over-paint from interior wood trim
I am getting my house ready for sale after I had rented it out for about two years. For some reason, I let the renters paint... let's just say that they did not mask the wood trim & baseboard before they painted. What is the easiest way to get all the paint off? Am I going to have to sand everything? I'm hoping there is some solvent that will do the trick without discoloring the wood, but that may be wishful thinking. Thanks in advance for any help,
Steve
p.s. I have already decided to remove the baseboard to do the cleanup because I'm having all the flooring replaced anyway.
sestivers is online now   Reply With Quote
Old 08-13-2007, 05:57 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Well, honestly there's not much to do about that now, but it could depend on what the finish on the trim was
It sounds like it wasn't painted
If it was, try a putty knife and if needed, some Oops! or Goof Off!
If it was stained and poly'd, there's a chance a putty knife and some Oops! might get it off
If it was natural, or merely stained, there's not much that'll work
The putty knife might pull off the "drip", but it may leave a spot where the drip was
slickshift is offline   Reply With Quote
Old 08-13-2007, 09:04 PM   #3
sestivers's Avatar
Rewards Points: 101
It is bare wood. So are you saying that not even sanding will work?
Old 08-13-2007, 09:47 PM   #4
slickshift's Avatar
Bare wood....that didn't occur to me in a rental..sorry
Sanding can work
How well depends on how old, how bad, and what type of wood and paint it is
If it's a lot of splatter, and it soaked in well, it could take a bit of an effort to get it clear enough for stain or poly
But technically, you can always sand out bare wood
How to paint trim, fascia? martyshel Painting 7 08-10-2007 10:48 AM
Have oak trim everywhere, what paint on walls? Mr. Michael Painting 6 01-24-2007 05:12 PM
Removing spray paint from tools harold938 General DIY Discussions 15 12-17-2006 08:16 AM
oak trim, caulking and paint question THEBIGPUNN Painting 2 06-05-2006 10:28 PM
Removing paint from hardwoods amclaugh Flooring 4 09-17-2005 09:49 AM
