Removing Old Thick Wallpaper Past - Painting - DIY Chatroom Home Improvement Forum
Old 11-10-2011, 08:09 PM   #1
Removing old thick wallpaper past
Doing a bathroom remodel and I had to tear off vinyl wallpaper, no problem. I got all the paper off but I've never seen glue that thick before. It has almost a fabric texture to it and in some places it has flaked or crumbled off. The stuff is hard even after I had soaked the paper to remove it. I had a sharp scraper, but that didn't seem to remove any of the glue. How do I get that glue off without messing up the paper surface of the drywall?
Pierson Paint is offline   Reply With Quote
Old 11-10-2011, 08:16 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Get a mister or garden sprayer- a sponge will also do.
It is most probably a brown paste- clay based. Get it wet to almost dripping, let soak, do again. use a 6" & 4" putty knife when soft to scrape most off- rewet as needed.
Sponge off any residue after scraping.
Let dry, sand to get any roughness and most definitely prime with Zinsser Gardz- an oil prime will also work but this is easier and faster. this will seal in any paste residue left and give a good base for either paint or reapplying paper.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 11-10-2011, 08:40 PM   #3
Gymschu's Avatar
Rewards Points: 240
If it's a clay based wallpaper adhesive, it is indeed a nightmare removing it from the walls. As Brushjockey said, wet it with a garden sprayer and keep wetting it! It will basically turn into mud. Follow BJ's advice to a "T" and you will have new walls once again. The only other option is to sand it with a palm sander but the dust you will create will be awful!
Old 11-10-2011, 09:27 PM   #4
When you say brown paste, clay based, are you also saying that the appearance would be brown in appearance? If so, this paste is white and when I would wipe with a sponge, white would come off on the sponge. Thanks for the replies.
Old 11-10-2011, 09:38 PM   #5
If it's white it is what is called a clear- much easier but still follow my instructions. Really the hard part will be seeing it. But it will soften easier.
Old 11-10-2011, 11:06 PM   #6
Windy Painters
Windy Painters's Avatar
Send a message via Skype™ to Windy Painters
Spray and scrape
Use garden pump and hot water. Spray two times with 10 interval. Use 8-10 in trowel to gently scrape the glue. After that wash the walls with pretty hard sponge. 2-3 times. Change the water. Next day when the drywall is dry - prime it - I would use Zinsser Oil-based - Cover stain. I trust more to oil.
And now you are read to skim coat
Chicago painter
house painter
exterior painter
Windy Painters is offline   Reply With Quote
Old 11-11-2011, 05:02 AM   #7
Green 3M scouring pads are also helpful. I did a house with clay throughout. No fun. Good luck.
Old 11-11-2011, 05:08 AM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 146
Chicago painter
house painter
exterior painter
I know you do not know the language well so let this be a lesson for you
It is ADHESIVE or PASTE , not glue. Do NOT make this mistake again or the paste police will show up at your'e door and take you away
The Following User Says Thank You to chrisn For This Useful Post:
Gymschu (11-11-2011)
Old 11-11-2011, 05:10 AM   #9
chrisn's Avatar
Rewards Points: 146
To the OP
http://www.wallpaperinstaller.com/wa...stripping.html
http://www.safeandsimple.com/
Old 11-11-2011, 08:39 AM   #10
Everyone thanks for the input. Chrisn I PROMISE I will never refer to wallpaper ADHESIVE-PASTE as glue, maybe.
Old 11-11-2011, 04:06 PM   #11
Mr. Paint's Avatar
When you put hot water into your garden sprayer (Hot, not warm) add DIF Wallpaper Remover Solution to the water. This will make the adhesive easier to remove. Wash the walls (Twice is good advice) using the same DIF and hot water mixture and rinse thouroughly with clear water. When the wall is dry, moisten your finger and touch the wall. If you did a good job, you will feel no "tack." If there is a tack, wash and rinse again
Mr. Paint is offline   Reply With Quote
Old 11-11-2011, 04:57 PM   #12
Mr. Paint, welcome to the forum. Your experience will be a benefit here. I would make two clarifications to your input. If we're talking clay ADHESIVE (keeps the cop away), I don't think DIF will be useful. There is a reverse tack as well. If Roman 35 (?someone correct me if wrong) was used, the walls will feel tacky on dry touch, but not tacky on wet touch. I had been experiencing that Roman product for years, but never knew what it was. I only knew that whatever it was, it wasn't coming off and I just oiled over it. That was discussed on a thread a short time back.
Old 11-11-2011, 06:01 PM   #13
chrisn's Avatar
Rewards Points: 146
Well thats good but I was actually referring to" windy"
Old 11-11-2011, 06:09 PM   #14
Chris has everyone askerd.
Old 11-11-2011, 07:49 PM   #15
Ok, I got the walls cleaned this morning. I ended up not using any of the suggest remedies except hot water and added one cup of BIZ laundry brightener per one gal. of water. Talked to a person locally and she said she had tried many of different methods of removing adhesive and she preferred Biz. She said spray it on wait about three minutes, not much longer because it could affect the paper on the drywall. Well it worked for me. So here's another way to remove paper adhesive. Thanks all!
Painting over wallpaper - no other option - How to proceed kuj0317 Painting 15 07-25-2011 05:25 AM
retexturing drywall after removing wallpaper dmcbride Painting 3 04-12-2010 07:30 PM
How to tell if all wallpaper glue is removed? CameraGuy Painting 11 04-04-2010 07:31 PM
Removing wallpaper and then painting applesusan Painting 7 02-24-2008 05:32 PM
wallpaper on untreated drywall... rjralston Remodeling 4 09-09-2006 01:13 AM
