Removing Old Paint From Tile - Painting - DIY Chatroom Home Improvement Forum
Old 01-17-2009, 10:49 AM   #1
Rewards Points: 77
removing old paint from tile
I have black & white tile on walls in bathroom with some sloppy over paint from past years. Would steel wool work to remove paint without dulling or scratching the glaze on tile surface?
Open to any suggestions, thanks.
dbldee20 is offline   Reply With Quote
Old 01-17-2009, 11:30 AM   #2
Rewards Points: 506
I'd recommend stripping. Steel wool will most definitely dull the finish.
That's going to be a tedious, messy, smelly (wear a cartridge respirator) job... I don't envy you.
SirWired
sirwired is offline   Reply With Quote
Old 01-17-2009, 11:43 AM   #3
Rewards Points: 77
I should have mentioned, its mostly on tile that borders casing & trim around door, clothes shoot, window etc...Not the entire wall.
Old 01-17-2009, 01:28 PM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Have you tried scraping it off at all?
I'm not an expert here, but we had a similar problem in our last house. It was paint splatter all over the porcelain sink and toilet. I tried acetone and a plastic putty knife and it scraped off easily.
If it is porcelain tile you might give it a try. Somewhere inconspicuous might not be a bad place to start.
Old 01-17-2009, 03:10 PM   #5
Rewards Points: 2,906
If this is glazed wall tiles, the easiest way to get paint off of it is by scraping it off with a razor. You can buy razor scrapers at any hardware store.
You'll probably need to use a paint stripper to get the paint off the grout joints, tho.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 01-17-2009, 03:37 PM   #6
Rewards Points: 77
Its old oil based paint. I hadn't thought of the razor, sounds like that will work.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
