Removing Old Paint From Molding? - Painting - DIY Chatroom Home Improvement Forum
Old 02-08-2008, 11:00 AM   #1
Removing old paint from molding?
previous home owner obviously did a quick job on the wall painting before selling. got a lot of overspill onto the wood molding.
is there an easy way to remove this, other than scraping/sanding it all off by hand, and then having to re-stain all the wood? i was thinking maybe a touch of paint stripper, but i'm pretty sure that would remove the varnish from the molding too?
batesrt is offline   Reply With Quote
Old 02-08-2008, 12:09 PM   #2
http://www.valsparglobal.com/val/resident/goof-off.jsp
mark942 is offline   Reply With Quote
Old 02-08-2008, 02:30 PM   #3
Originally Posted by mark942 View Post
won't that remove the stain/varnish from the molding as well?
Old 02-09-2008, 05:23 AM   #4
It is easier on wood work than paint stripper. Or sand paper.I have used this product for quite some time now and have had great results...........
Old 02-09-2008, 06:51 AM   #5
Tired, Cold, and Damp
slickshift's Avatar
Usually a putty knife is the best option
It can be daunting, but frankly it's not a good situation
Mostly it will depend on how fresh the drips are, and what coating exactly is on the trim
If it's just stain, then don't bother
Scrape, sand, primer (oil), and paint
If it's some sort of oil-based poly or lacquer/shellac, then Oops! or Goof Off! may help with removal
You are better of scraping as much as possible first though
previous home owner obviously did a quick job ...before selling
I can't tell you how many of these "we don't care (about the right way or quality) we're just putting on the market" jobs give the buyer way more of a mess than if they had just left it alone
slickshift is offline   Reply With Quote
Removing paint from hardware ciera Painting 11 09-10-2007 10:03 PM
Blotchy crown molding paint lewlewjones Painting 7 05-13-2007 04:31 PM
Removing spray paint from tools harold938 General DIY Discussions 15 12-17-2006 08:16 AM
Removing Paint from Bricks ? Piney Painting 7 11-16-2006 02:17 AM
Removing paint from hardwoods amclaugh Flooring 4 09-17-2005 09:49 AM
